Mass Air Flow Sensor
Like Tree3Likes
Old 15 Oct 2010, 04:34 pm
Default Mass Air Flow Sensor
Hello all,
I am new to the forums and have a question or a dozen questions, but I will start with this one first.
Where is the MAF sensor on a 2003 PT.
I am getting codes P0171 (which does not seem to have any specific root cause) and P0522 (oil pressure sensor)
I cannot find where the MAF sensor is on my car. I cannot find pictures of it, and none of the parts stores seem to carry the part for the PT. Is there one? I read that a dirty sensor can cause starting and running problems, and I got both.
Car is an automatic with no after market anythings. 105,000 miles.
Intermittently the vehicle will either start right up, sound like it wants to start, but wont on the first try (second try starts right up, and runs fine), or it will take 7-8 or more tries to get the engine to come to life.
CEL comes on at random, does not affect the quality of the idle or the drive.
Oil light comes on at random then goes off a couple of minutes later.
When I am at a red light/ stop for any reason, can put foot to floor and car does not go, then kicks in causing me to peel out. This usually only happens when the AC is on, but has been happening even without the AC lately.
Any help recommendations would be helpful
thank you.
Old 15 Oct 2010, 05:22 pm
Freezinghot's Avatar
Default Re: Mass Air Flow Sensor
P0171 Fuel Trim System Lean Bank 1
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
The mass airflow sensor should be on your air tube thats connected to your throttle body. Its going to go into the tube itself
It often just gets dirty, so try cleaning it before actually buying a new one
Are you leaking any oil?
04 graphite(vroom!) N/A Limited 110,000 miles -original owner. Custom short ram intake ( CGS motor-sport pipe, specter open-end air filter, specter breathing hose),OEM spoiler, Pioneer receiver ,10" bazooka sub,Blue LED interior lighting, Bosch +4 plugs and Accel super stock 8mm universal plug wires.
Old 15 Oct 2010, 05:32 pm
Wrong, the MAF mass airflow sensor is at the top of your intake manifold back just across from the radiator overflow bottle. It has wires running from it to the PCM. It has a plug-in connector. The sensor that you described is the AIT. "Air Intake Temperature" and pushes into the FTTB "Filter To Throttle Body" pipe.
Jerry
Old 15 Oct 2010, 05:36 pm
Jerry
I was under the impression that that was the MAP sensor. Never had to replace it, so i guess i cant be sure.
Sensors are always a pain, ill take my old cars any day!
Old 15 Oct 2010, 05:53 pm
It depends on who you're talking to and how your particular engine is fed. If it's a turbo then it's commonly referred to as a MAP because it's measureing the "Pressure" that is created by your turbo in the manifold, thus MA"P". On the N/As its called an MAF because its measureing the air "Flow" through the intake, thus MA"F". It gets even more confusing when you try to find it in the Haynes manual because it calls it both names in the same paragraph ( section 6-8, left hand column, topic #9, steps 2 and 3) it goes by both names in the same paragrah. Maybe they were just covering all their bases?
Jerry
Old 20 Oct 2010, 01:59 am
I seem to leave little spots occasionally... they appear to b from the rear of the engine, but having dealt with leaks before, I know that where the spot is may have nothing to do with the leak site.
Old 08 Dec 2010, 02:02 am
i have damage mass airflow sensor before...
it sends wrong input signal to the electric control unit which wrongly activates other components.
these sensors are extremely sensitive replacement parts.
________________________________________
Why does my car need a mass air flow sensors?
Old 06 Jun 2016, 03:30 pm
Can maf sensor cause exceleraton issues , that is engine losses power like a miss?
Old 06 Jun 2016, 03:50 pm
SPLNeon's Avatar
Please research this a little more. The pt cruiser uses a speed density system for monitoring the air "pressure" inside the intake manifold, combined with an intake air temp sensor. We do not have a MAF sensor.
THE UNDISPUTED KING OF THE PARKING LOT
Competition's paying the price.
03 PT GT. DSI canned tune, Weight redux, MH Racemaster Slicks/Rota Slipstream 15" 11.95 at 118.41mph 1/4 mile
96 SOHC Neon Turbo
08 CSRT4. Realtune MS1K v1 pcm stg0 NSRT4 Injectors.
Old 06 Jun 2016, 04:47 pm
Hayne and Chilton seem to think it's a MAP.
BUT, like Jerry pointed out, in the write-up next to the picture, it calls it MAP and MAF in the same paragraph.
EGR flow 400 2k1PT Tech & Performance Forum 20 01 Jan 2014 08:46 pm
What does "mass airflow" mean in fault/error codes? Krazkat Tech & Performance Forum 3 04 Nov 2009 09:36 pm
Cam Sensor code changed sensor still dead RottenKid Tech & Performance Forum 8 18 Nov 2008 08:17 am
Any local RI, Eastern Mass Cruise ins? PTGT Redman Northeast PT Forum 0 18 Apr 2004 10:17 pm
Hi Flow Cat Blade Tech & Performance Forum 3 15 Mar 2004 07:31 pm
