Hi Yall- New 05 pt owner here- With Heavy whine when going straight 2.4 HO Turbo
Old 17 Oct 2010, 07:16 am
Default Hi Yall- New 05 pt owner here- With Heavy whine when going straight 2.4 HO Turbo
Hi Yall- New 05 pt owner here- With Heavy whine when going straight 2.4 HO Turbo.
I am thinking its "The dreaded bearing issue" But after reading they say the bearing noise is when you make turn and not when going straight- Mine is definitely when going straight - Any tips would be greatly appreciated,
Joe
Old 17 Oct 2010, 09:19 am
Default Re: Hi Yall- New 05 pt owner here- With Heavy whine when going straight 2.4 HO Turbo
Joe,
I deleted your other post. No need to post the same question twice.
Have you tried isolating the whine to either the engine or body? We can take good guesses at your whine but helping to narrow it down would help. Try duplicating the whine with someone else in the car that can help you narrow it down. Also, other things like, does the pitch of the whine go up and down with speed? Does it do it in reverse? Also the whine could be coming from the tires. If your out of alignment, the tires start to wear unevenly and will start to wine at a particular point.
Impending turbo doom, or just a clogged oil return line causing whine and smoke? icezebra Turbo Performance 5 05 Oct 2008 04:14 am
Uncommon Turbo whine turbomangt Turbo Performance 3 27 May 2005 11:09 pm
Howdy Yall ! ATLPTGT General PT Cruiser Discussions 4 14 Jan 2005 08:28 am
Wasn't a turbo whine after all Mike-in-Orange General Turbo Discussions 9 03 Feb 2004 01:35 pm
PTTuning straight thru axle-back exhaust for Turbo CraigO Turbo Performance 7 08 Jun 2003 12:43 am
