oil pan gasket replacement
Old 21 Oct 2010, 09:21 pm
mash35231's Avatar
Question oil pan gasket replacement
My ole PT has a oil leak coming from the back side of the oil pan. It's a very small leak but it does "mark it's spot" over night. I'm going to replace the oil pan gasket and oil filter mount gasket. I've been using a Haynes repair manual for reference for all the repairs on the car. If anyone has done this repair any "lessons learned" from experience will be greatly appreciated.
Old 24 Oct 2010, 01:11 am
mash35231's Avatar
Default Re: oil pan gasket replacement
I replaced the oil pan gasket today...took about 5 hours...worst part was cleaning the oil pan...I hope I never have to do that again...
Old 24 Oct 2010, 08:06 am
That's how I felt about the transmission pan. You'd think it wouldn't be that hard to put a silly drain plug in the pan, but with the filter being on the inside, you have to drop the whole pan. FYI, if you decide to do the transmission drain and refill yourself, buy the filter kit from WIX. Not only do they make excellent filters, but that kit comes with a new rubber gasket. It took me a long time to scrape the old gasket material off the pan and clean it up, but when I did it looked totally new. Oh, and I put down a shower curtain liner under the car cause that is a really messy job and hot transmission fluid will go everywhere.
2005 2.4L Non Turbo
low vacuum, hard start after hd gasket replacement hondoland Tech & Performance Forum 6 31 Jul 2010 07:41 am
head gasket how to tell if bad BeagleDad Tech & Performance Forum 18 18 May 2010 09:53 pm
gasket superpug666 General Turbo Discussions 15 24 Jun 2009 11:21 pm
valve gasket onyx pt Turbo Performance 1 29 Jul 2007 04:17 pm
Head Gasket Kirby Stage Turbo Kits 7 04 Nov 2003 10:59 pm
