Oxygen sensor
Old 22 Oct 2010, 07:29 am
Send a message via AIM to Laural
Unhappy Oxygen sensor
Hello fellow cruisers!
I'm a newbie here and I have a question. Had my car serviced
after after a fender bender. They changed tensioner, belts
and air compressor! They claimed I bent the chasis on the right
front passenger side. all fixed ( although I thinnchasis may have
been pre existing) 2008 cruiser engine lite is on still!
They're saying it's 02 sensor! Not part of the accident! Ugh!
Is it possible to clean/ change the sensor myself seems to
be easily accessable. Special tools? Any info will be greatly
appreciated! Thanks
Old 22 Oct 2010, 07:46 am
Default Re: Oxygen sensor
IF you change it, make sure it is OEM as our PT's do not like aftermarket sensors. When they changed tensioner etc, did they also change the timing belt. If not, it should be done at 100,000.
Old 22 Oct 2010, 08:10 am
Yes changed the timing beltvand I just checked the code
said po 137 done--------- does that mean it's ok?
Old 22 Oct 2010, 10:39 am
Unhappy Re: Oxygen sensor
Error code po137 done ----- obviously means
not done engine lights still on the sensor doesn't
just pull out easy I'm affraid to yank on it
don't want to break anything else!!!HELP!
Old 22 Oct 2010, 11:34 am
Kawizx9r's Avatar
Think you misinterpreted that.
When you do the cycle to bring up error codes, it'll go through all the codes (1-2 second in between each code) and once all codes are displayed it ends with 'Done' meaning there are no more codes to display. Your problem still persists, and I can't recommend anything myself but just thought I'd give you that heads up.
Kawi is a friggin genius!
Old 22 Oct 2010, 03:41 pm
If you're looking at a sensor that appears that it should pull out, then you're not looking at either of the two 02 sensors. They unscrew---grudgeingly and they are not easy to get to. One is on top of the exhaust manifold and the other is on the catalitic convertor. Also no, you can not "clean" an 02 sensor.
Jerry
Old 24 Oct 2010, 08:11 am
What about the wires attached to it does the whole thing come with wires attached I'm so not good at this stuff!
Old 24 Oct 2010, 08:57 am
The wires (usually 4) will go to a plastic (gray or black) electrical connection. The connection has to be taken apart so the sensor can be removed from the car. The new sensor with come with the wires and plastic connection.
Unless you buy a universal sensor and sometimes they come with the wires without the electrical connection.
Old 29 Oct 2010, 12:10 pm
Ok changed the 02 sensor did the ignition
dance no code then shows --DONE---
will the engine light go out eventually or, is there
some way for me to clear it on my own?
Thank you by the way you have been very
helpful and knowlegable!
Old 29 Oct 2010, 12:42 pm
Remove the negative cable from the battery for about 10 minutes, that should do it.
Oxygen Sensor luvmypt Tech & Performance Forum 15 23 Aug 2017 04:32 pm
oxygen sensor location hamlaker Tech & Performance Forum 3 13 Aug 2010 05:40 pm
Timing belt change, then CEL code for oxygen sensor? p_ridge_pt Tech & Performance Forum 1 05 Jul 2010 05:15 am
Oxygen Sensors Myron12 General PT Cruiser Discussions 5 14 May 2008 11:58 pm
Oxygen Sensor??HELP?? mjb457 Tech & Performance Forum 0 22 Jul 2007 09:56 am
