Engine Light ON - no error code
Old 22 Oct 2010, 10:13 pm
Default Engine Light ON - no error code
So the yellow engine light jumps on last week. My buddy points me to this forum, and I learn how to pull error codes. ON-AC ON-AC ON-AC...
So after doing the key thing, I get the following:
-done-
Hmmmm, no error codes!? But the yellow engine light is still on!?
Any thoughts?
Old 22 Oct 2010, 10:39 pm
Kawizx9r's Avatar
Default Re: Engine Light ON - no error code
Reset the PCM by disconnecting (you can look under the fuse box) the 20a fuse or the negative cable from your battery for 5 minutes.
Plug it back in and it should reset. Should it come on again, hopefully it'll come up with an error code letting you know what the problem is. I had that happen to me once and it didn't come back.
My Toy
Kawi is a friggin genius!
Old 23 Oct 2010, 02:32 pm
As Mr K said (we don't know his "real" first name, hint), if you just want to get rid of the code, simply remove the neg. battery cable and wait a few minutes and then replace the cable. If the cell comes back and you REALLY only get ---done--- when you do the key dance, then you have a "deeper" code than the key dance can reach and you will have to go to the dealer or Autozone (free) , pepboys (free), your favorite mechanic, etc. to retreive the code.
Jerry
Tags
yellow engine light check
Engine Light on P0139 code shutterbug Tech & Performance Forum 6 25 Sep 2011 05:49 pm
P0304 code Engine Light On wedge22 Tech & Performance Forum 1 23 Feb 2010 07:02 am
Engine light P2097 error code help jbh1860 Tech & Performance Forum 2 20 May 2009 12:30 pm
MIL light and error code, pls help ruzz1 Tech & Performance Forum 11 01 Mar 2009 02:01 pm
P0325 Engine Error Code on 2003 PT Turbo intim3 General Turbo Discussions 0 12 Aug 2007 08:06 pm
