Electric Fan Replacement for a 2007 PT
Old 25 Oct 2010, 06:05 pm
Sharkstooth's Avatar
Default Electric Fan Replacement for a 2007 PT
Well mine is at 55,000 miles and started running rough at idle when i was at a stop light and the AC would blow warm but as soon as i started moving again it would run fine and blow ice cold. This has been happening for about 4 or 5 days and i checked the fan yesterday and found that it was not coming on at all so i kick started the fan and it turned very slow and was arching so its def fried,but at least the car stays running cool on the temp like always. My question is,what is the easiest way to replace the fan? I am a mechanic but its always nice to have advise to make things quicker because it looks like it will come out a couple diff ways and i plan on doing it at work tomorrow.Thank you.
Old 25 Oct 2010, 07:49 pm
Default Re: Electric Fan Replacement for a 2007 PT
They (Chrysler) changed things around a bit through the years, especially from 2006+ but for the most part it's the same....
Removing the fan and housing 01-05 PT
Old 25 Oct 2010, 09:57 pm
Thank you,it looks like it will only take me an hour to do and i love the detail that you put into your car.
Old 26 Oct 2010, 06:07 pm
Put the fan in on my lunch today and it only took an hour and works great and problems solved.
Old 26 Oct 2010, 07:14 pm
Glad it worked out for you.
2007 fan replacement fattmann Tech & Performance Forum 1 27 Jun 2010 05:45 pm
Question about replacement air vents on a 2007 skullvankrush Interior Accessories Forum 10 04 Jun 2010 02:44 pm
All Electric PT Woody CREWZIN General PT Cruiser Discussions 7 05 Sep 2009 01:29 pm
2007 touring audio replacement lucindrea Sound and Security Forum 7 25 Jul 2009 10:53 pm
electric turbo milPT Tech & Performance Forum 9 11 Mar 2005 09:01 pm
