Repair Questions: (3 )
Old 26 Oct 2010, 08:16 pm
mjb457's Avatar
Default Repair Questions: (3 )
Ok My NA PT has 86k miles(runs great) ok I keep up with it.(1)I put platinum plugs & wires in at 42k( how long can I expect?)(2) I changed tranny fluid & filter at 36K when again?(3) Timing belt when? most say 105k? All these items are expensive but needed so any recomendations are appreciated. MJB
Old 26 Oct 2010, 09:16 pm
Default Re: Repair Questions: (3 )
1) I put platinum plugs and performance wires in mine at 50K and I looked at them at 100K and they still look good. I'm going to keep on going till I feel some hesitation, ruff idle or cranking just a bit too long to start.
2) Did you do a flush or just a change of about 4-5 qts by dropping the pan? If just a 4-5 qt change, I'd do it again now.
3) Do the timing belt, tensioner and water pump at around 100K. If the serpentine and alternator belt haven't been done yet, do those also. Small additional price and they need to come off anyway.
Old 27 Oct 2010, 07:20 am
Agree (as usual) with Crewzin.
Depends on what wires you got - the plugs will be fine.
I say flush the auto every 50,000 miles.
Old 27 Oct 2010, 11:16 am
mjb457's Avatar
Thanks again.. can the wires on a non-turbo be changed without removing intake?? I know plugs cant ( I forget) Going to get trans fluid done again. MJB
Old 27 Oct 2010, 11:32 am
Originally Posted by mjb457 View Post
Thanks again.. can the wires on a non-turbo be changed without removing intake??MJB
Nope, must undo manifold, that is why we suggest doing both at one time.
Old 14 Dec 2010, 08:50 pm
Here i am again...sorry for the late reply...I agree on hooligan. but you also have to work with the tensioner and the timing belt..much better with a water pump at around 100k...check this one: Information on the Chrysler PT Cruiser
references: Automotive avenues, US Car Parts, Car Repair Questions, Auto Repair Manual
Top repair musicman8120 PT Cruiser Convertible Forum 8 17 Mar 2011 10:32 am
Repair Pro tinosa General PT Cruiser Discussions 0 30 Jan 2010 02:06 am
tie rod repair love bandit2 General PT Cruiser Discussions 0 06 Feb 2009 03:02 am
Have a few questions about headgasket repair adamf123 Tech & Performance Forum 11 13 May 2008 09:16 pm
Questions Questions..newbie DaShado PT Cruiser Convertible Forum 0 01 Apr 2006 12:22 am
