oil pressure light sticks on
Old 28 Oct 2010, 07:57 am
Default oil pressure light sticks on
My oil light does not go out with the original morning startup about half of the time. The oil pressure comes up after a moment, but there is a feature where after a short time delay, the light will lock on, and itís necessary to turn the key off and restart to get the light to go off. The light goes out promptly with every subsequent start of the day, and I donít think I have a real oil pressure problem, but this is obviously a condition I will not ignore. Itís an 05 Turbo lite about 60,000 miles and still under warranty. I have always used 5W-30 synthetic oil and have actually tried 3 different oil filters of various brands just to make sure itís not a filter drainback valve problem. I suspect itís an overly sensitive pressure switch rather than a bearing or oil pump problem, as it doesnít happen with every startup. I will be taking it in to the dealer soon, Iím just curious if anybody else has seen this.
On another note, my gas gauge stuck low with the low fuel light on this morning. I filled up, took six gallons and the gauge and light are now reading correctly. I havenít seen this problem before, have to wonder if anybody has seen this problem before either?
Old 28 Oct 2010, 08:20 am
Default Re: oil pressure light sticks on
There's been numerous cases with a failed oil pressure sensor. Usually replacing the sensor has fixed the problem.
Haven't seen anything about the low fuel light getting stuck.
Old 22 Nov 2010, 06:54 am
I replaced the sending unit, and that fixed the problem as expected. The gas guage issue was a one time thing, at least so far.
Headliner sticks in top at first fold? jedigirl77 PT Cruiser Convertible Forum 20 15 Jul 2011 01:20 pm
Oil pressure light problem - just replaced cam sensor jeremyrocksursox Tech & Performance Forum 5 02 Jul 2010 10:22 pm
Car Sometimes won't start (oil pressure light & Engine Light) gerardio Tech & Performance Forum 6 18 Jul 2008 08:22 am
Trim sticks gonzomania Interior Accessories Forum 11 07 Jun 2007 06:27 pm
Convertible Door Sticks->Can't get out 340x PT Cruiser Convertible Forum 0 23 Jan 2005 02:44 pm
