Showing ABS light, Brake light, Traction light on Dash
Like Tree2Likes
Old 07 Nov 2010, 06:10 pm
Default Showing ABS light, Brake light, Traction light on Dash
Hey guys...... Ran into a few problems with my 04 PT Non-turbo.... Cant find answers anywhere..
Over a month ago I filled my tank ith gas and not even 5 minutes later my check engine light came on.. Before I even had time to pull the car over it stalled out.. Started back up and made it home, bucking pretty bad...... I got the car over to the shop and they determined it was the ECM that was bad.. They said the wiring harness was fine.....
After I got the new ECM that was programmed to my VIN number of the car, mileage, etc..... The Check engine light went out and the car drove perfectly fine... The only problems were the ABS, Traction Control, and Brake light were on it the dash.....The car does not have ABS and doesn't have a traction control button... I thought I got the wrong computer so the company sent me out another.. Same problem..... They sent another.. Same problems....... I don't know what I should do now.. Need to get the lights off..... Has anybody run into a problem like this????
Old 27 Nov 2010, 12:02 am
Default Re: Showing ABS light, Brake light, Traction light on Dash
Anybody?
Old 27 Nov 2010, 07:25 am
Originally Posted by fox50h View Post
Anybody?
Your asking the question on a Holiday weekend where loads of people are away from their computer.
Did you try taking it to a dealer? I tried a search and there's loads of help to get the lights to go off but nobody ever complained about the lights when they don't have ABS or traction control in the first place.
Old 30 Nov 2010, 02:27 pm
Check your brake fluid. I have no idea why you'd get extra lights (ABS, TRAC)
Old 30 Nov 2010, 02:54 pm
Did you do the key dance to see what codes were being thrown? I would only replace an ECM as a last resort.
What year car is it?
Old 08 Jan 2011, 07:22 pm
I talked to the dealer about the problem... Said they didn't know what the problem could be.. kept saying it MAY be a faulty computer but as I stated this is the third computer from this company...
The car is an 04....
Old 11 Jan 2011, 09:00 am
I'm just guessing, but seems they sent you wrong PCM - for a car with ABS and TRAC
Old 12 Jan 2011, 08:47 am
I would have thought that too but they sent me a total of 3 pcms and each time i told them it had no abs and no traction.
Old 12 Jan 2011, 12:14 pm
The ECM is probably correct, but incorrectly programmed. As 03Elect asked, are you throwing any codes??? You can take it to most any large chain auto parts store and get them to read your codes, I would suggest that. See if there is anything showing up. If not, they probably just have it programmed wrong, and if it were me, I'd find another stealership to go to, sounds to me like the one you're taking it to doesn't know it's arse from a hole in the ground.
Old 12 Jan 2011, 01:16 pm
I work at a mechanic shop.. Did the OBDII scan and had no codes..
car wont start. car alarm light and airbag light on trigimon Tech & Performance Forum 7 05 Nov 2010 03:42 pm
2001 PT Cruiser-- ABS and Traction light killamken General PT Cruiser Discussions 0 05 Jul 2010 08:52 am
Car Sometimes won't start (oil pressure light & Engine Light) gerardio Tech & Performance Forum 6 18 Jul 2008 08:22 am
LUMINICS head light and fog light bulbs 03baggedturbo Vendors & Buyers Forum 8 22 May 2008 08:36 am
LUMINICS head light and fog light bulbs 03baggedturbo Classifieds: For Sale/Trade 0 12 Dec 2004 09:05 pm
