Having some idle issues after head gasket repair
Old 09 Nov 2010, 04:33 pm
Default Having some idle issues after head gasket repair
Hey, guys i have done tons of searches but nothing exactly my case. I got this car for pretty cheap with a warped head, I took it all apart had the head redone, new timing belt, water pump, and motor mounts. Now after getting it all back together the car does not idle well very jumpy and low, but fine at all other speeds. I have 2 codes one the tps and the other the low speed fan relay. I took off the tps and tested it with a ohm meter and it was a smooth reading open through closed. Should I replace the tps anyway???? I need this thing running properly pronto. Please help thank you
2.4L non turbo 89,000 miles
Old 09 Nov 2010, 04:39 pm
Default Re: Having some idle issues after head gasket repair
I also did a compression check and they are all the same, rechecked the timing marks and all lined up, what else am i missing????
Old 09 Nov 2010, 04:48 pm
You said you rechecked the timing marks. Did you actually take it all apart again? Almost everyone that comes back to the forum after a timing belt change and rough idle, turns out to be off timed. Even the people that had a mechanic without experience with the cruiser, come to us and ask about rough idle, when they go back to the shop, turns out to be be mis-aligned timing marks.
As far as the TPS, that's up to you if you should replace it if it checks out OK. How about the low speed fan, is it working?
Old 09 Nov 2010, 07:49 pm
so with the mark off it will still run without hitting anything??? I set the marks just like the book said and turned it over 2 times, is their any way to see the crank mark without removing the crank pulley?? the cam marks are still lined up but I cant see the crank mark but #1 piston is up. Should I take it apart and make sure all 3 marks are good??
I am wating to get the new fan motor before I change the relay the fan won't come on even when I jump it
Old 09 Nov 2010, 08:07 pm
I can't answer your questions about the cam marks. Hopefully someone will see this thread and give you more advice about it.
The fan motor, could also be your source of a rough idle. If it's not running, you'll only feel the results of the heated engine at idle and once you get going (above 35mph) the fan shuts off because there's enough air coming through the front end to cool things off. Below that, the fans are suppose to come on and keep things cool.
I would work on the fan problem first (get both speeds working) and see if that clears up you rough idle problem.
Old 10 Nov 2010, 12:49 pm
re: the crank mark. That damn huge metal motor mount deal with the large star bit going through the fender is whats keeping you from seeing the crank mark. If you can manage getting that out of the car (with the motor on a jack) you ought to be able to see right down into the space where the crank mark resides with a big light.
If I recall its not needed to pull the crank pulley again to get that far.
Old 10 Nov 2010, 06:12 pm
finally I got it, my stupid butt set the inner marks together but not the outers, fixed that and fired right up. thanks guys
Old 21 Jan 2011, 10:22 pm
guys...good to be here. I apologize for the disturbance. Just have some queries. it happened that my PT 2004's head gasket got damaged. my problem was i need to replace it. Only then, i couldn't find a store that sell such stuff. where can i find it. any suggestions or offers to give? Thanks
kenstockhouse@yahoo.com|car repair guide
Old 22 Jan 2011, 05:39 am
Your profile says that your occupation is an "automotive technician". Now tell me how an auto tech can't find a simple thing like a head gasket?
Old 22 Jan 2011, 07:36 am
lol Crewzin, my thoughts exactly, no need to bash the guy
try Rock Auto they have everything you need.
Head gasket ? bds02pt Tech & Performance Forum 33 29 Sep 2011 08:30 pm
head gasket how to tell if bad BeagleDad Tech & Performance Forum 18 18 May 2010 09:53 pm
Head Gasket / Radiator issues Craicgirl General PT Cruiser Discussions 2 26 Sep 2009 07:23 am
head gasket broadleaspeaking1 General PT Cruiser Discussions 1 27 Mar 2008 05:44 am
Head Gasket Kirby Stage Turbo Kits 7 04 Nov 2003 10:59 pm
