engine misses when cold
Old 10 Nov 2010, 07:07 am
Default engine misses when cold
2001 pt crusier When engine is cold it misses bad and doesnt want to run,but when engine warms up to almost operating temp then it smooths out and runs good. i've done all the checking for air leaks and intake leak when it was running cold. So HELP you all i'm open for any ideas i'm old and on a fixed income so any help would realty be appreciated. Thank you
Old 10 Nov 2010, 06:42 pm
Default Re: engine misses when cold
Aren't we all.
What kind of mileage are we talking about? When was the last time the plugs and plug wires were changed?
Old 10 Nov 2010, 07:26 pm
BladeRunner's Avatar
I had a slight hesitation off idle, I ran a can of Sea Foam through it and it cleared up, I also cleaned the throttle body..that WAS dirty! Aside from that, regular tune up stuff should help...mine has 205,000 km..so it needs a bit of TLC in the engine dept..
Old 11 Nov 2010, 12:00 am
When was the last time you changed your air filter?
Where are you living so we can get a grip on what you mean when you say "cold".
Old 11 Nov 2010, 06:16 pm
Good plugs and wires,clean air filter, This is a really bad miss it won't hardly get out of it's own way I mean a bad miss. There is also no codes except for one about battery has been disconnected less 50 miles ago.
Old 11 Nov 2010, 07:04 pm
If it's nothing we have suggested above and there's no codes, it's time for you to get it hooked up to a scanner at the dealer or a mechanic to help pinpoint your problem.
Old 11 Nov 2010, 09:51 pm
ProDigit's Avatar
You may want to try medium or premium gas (super or eurosuper if you live in Europe) for a while, to see if you get any improvement.
Upon Cold Start in Cold Weather, Loud Noise?? paulrosenthal Tech & Performance Forum 33 01 Oct 2014 09:55 am
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Engine stall while cold! myhotwheel Canada PT Forum 0 26 Nov 2009 01:52 pm
Replaced thermostat, but engine temp says cold while driving... missingwhatsnear Tech & Performance Forum 5 11 Feb 2009 08:39 pm
Cold Cold Crazy PianT General PT Cruiser Discussions 13 21 Jan 2004 11:35 pm
