1ST SMALL PROBLEM W/ 2007 PT
Old 10 Nov 2010, 09:23 am
Default 1ST SMALL PROBLEM W/ 2007 PT
HELLO, IM NEW TO THIS FORUM & WANTED TO ASK...
IVE GOT A 2007 PT CRUISER W/ 60,000 MILES, JUST HAD AN OIL CHANGE & CHANGED THE BATTERY. THE PT IS STARTING TO "CHOKE" A LITTLE WHEN IM ON IDLE & HAVE THE A/C RUNNING AT THE SAME TIME. ITS NOT MAJOR, HASNT ACTUALLY TUNED OFF OR ANYTHING, BUT WANNA SOLVE THE PROBLEM BEFORE I GOTTA CALL AAA FOR A TOW. ALSO, IVE HAD THIS HAPPEN WHEN IM GOING ABOUT 2MPH AND MAKE A SHARP TURN (LIKE TO GET OUT OF A PARKING SPOT). ITS PRETTY WEIRD....
ANY IDEAS ON WHAT THIS COULD BE COMING FROM???
Old 10 Nov 2010, 12:38 pm
Default Re: 1ST SMALL PROBLEM W/ 2007 PT
plugs/wires ez cheap insurance there. gap them at 0.40 - 0.35.
Turbo or not?
Old 10 Nov 2010, 07:48 pm
I agree with Bob. I've got a 2006 w/59,400 that was doing the same thing while idling and running either the heater or AC. Last weekend, I changed plugs and wires. I also cleaned the throttle-body with some Berryman's B-12, some clean rags, and q-tips for the areas where the butterfly meets the edge (make sure to check that there's no debris left from the rag/q-tip before re-assemble.)
I was a little nervous because I hadn't done any of this in a while, but using this post made it super easy:
2006-Up Pt Cruiser Spark Plug Removal.
Anyhow, the choking/rough-idle is gone, and my baby is running smooth again
Old 10 Nov 2010, 08:03 pm
mdfrodolives's Avatar
Verela, does this "choking" seem more like the engine is "stuttering"--like it wants to die? Then it idles okay for a few seconds, then "chokes" again? And it happens mostly at idle--and not out on the highway?
Does it only happen when using your Air Conditioner? You said it happens when going 2 Miles per hour. That's pretty slow. And if true, the engine is not running much above idle--if that's a true speed.
Let us know.
Tim
Old 11 Nov 2010, 05:52 pm
Matt42's Avatar
I agree with Bob D. Plugs & wires. Could also be the radiator fan assembly: High speed fan going south. If it does not do this with the AC off, that's diagnostic.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Turn Signal Problem 2007 Pt Twinb2 General PT Cruiser Discussions 4 26 Sep 2012 02:46 pm
2007 Pt with a transmission problem Sam31 Tech & Performance Forum 10 10 Nov 2010 09:28 am
new 2001 cruiser.....small problem....help?? superbert1971 Tech & Performance Forum 17 11 Mar 2009 08:10 am
2007 Driving Lights (Installation Problem) vinzchlortho Exterior Accessories Forum 3 30 Apr 2008 10:59 pm
Small scratch KingKole02 The Detail Shop 4 12 Feb 2004 11:31 pm
