I've reused mine 3 times without any problem.
I am on my 2nd go no problem
Okay, I got the upper manifold off, sort of (I relied on the Hayne's Manual instructions. I should have simply used the second Spark Plug Removal "Sticky" in this forum, instead. Hayne's makes no mention of removing "both" throttle body to throttle body bracket bolts. They just mention the one 13 mm bolt under the throttle body--at the driver's side. That's not cool. They obviously did not actually do this procedure. There is also another 13mm bolt behind-and-to-the-driver's-side of the throttle body. This bolt is the second one that holds the throttle body to the throttle body bracket. I was unaware of this bolt until later--and so my clearance while lifting up the upper manifold was limited--but adequate. Although, if I had forced the upper manifold up as high as Hayne's said I could, I'd have pulled out the second 13 mm bolt from upper manifold--and cost myself a lot of money for a new upper manifold.)
I reused my old gaskets (upper manifold to lower manifold), and there were no leaks. I changed my thermostat. The old thermostat seal was leaking and you can't just buy a new seal. But after 7 years, $17.00 for a new OEM thermostat isn't too dear. Besides, you have to position the thermostat into the thermostat housing cover first--a particular way. The whole thermostat/gasket assembly has a nub to guide you, and the thermostat stays stuck into the housing as you lower the whole works onto the thermostat housing. I was going to change out my old coolant, too, but couldn't get the draincock to turn out properly. Being a tight-fisted miser, I did not want to strip out the radiator drain hole, so I just turkey-basted the coolant down to a manageable amount to remove the upper radiator hose and the thermostat housing. It was duct-tape mechanics all the way. But it worked. Thank God for torque wrenches. 105 inch lbs. for the upper manifold bolts. 110 inch lbs. for the thermostat housing cover bolts. I got a Craftsman Microtork a few years back for Christmas--and it worked like a charm. It really takes the fear out of tightening small bolts .... Thanks for the tips, guys! Tim |
Good job Tim. It's a good thing you don't have the 01-02 cruiser. There's a EGR tube in back of the manifold that needs to come off and it's a PITA to work on. It has two different size bolts and you almost need to be a contortionist to get to them. The manifold won't lift up without taking the tube off first.
Crewzin, that EGR fiasco assembly is very close to where the second 13mm bolt I neglected to take off, is located. Still, when I do my plugs and plug wires in about 10,000 miles, now I know there's another bolt to contend with. At least it's only one on the back of the upper manifold-to throttle body--and not two ... and two of different sizes, no less.
The guy who designed that EGR arrangement must have been the guy who designed that silly draincock .... Tim |
+1 on reusing the same gaskets, my PT has 205K & I just did my plugs & wires on Saturday. I thought the gaskets might be "flattened" after 10 yrs but they are fine. There are only 3 bolts holding the throttle body to the intake so I took it off & gave it a good clean up...I had sprayed it while on the car earlier & it looked clean,but,I found the "back" side was pretty dirty..so it was worth it to take it off and do a proper job.
I had mentioned in another thread that I had an exhaust odor inside when I had the heat/AC fan running...Well it turned out to be the PVC valve! ![]() ![]() |
Thread Tools | |
Display Modes | |
Head gasket ? | bds02pt | Tech & Performance Forum | 33 | 29 Sep 2011 08:30 pm |
gasket | superpug666 | General Turbo Discussions | 15 | 24 Jun 2009 11:21 pm |
head gasket | broadleaspeaking1 | General PT Cruiser Discussions | 1 | 27 Mar 2008 05:44 am |
valve gasket | onyx pt | Turbo Performance | 1 | 29 Jul 2007 04:17 pm |
Head Gasket | Kirby | Stage Turbo Kits | 7 | 04 Nov 2003 10:59 pm |
