Clearing codes.
  • 1 Post By mdfrodolives
Old 14 Nov 2010, 10:29 am
Default Clearing codes.
Can anyone tell me how to clear the codes from a 2002 PT cruiser?
I have the codes retrieved and will be replacing the egr today.
* thanks for the info on how to replace the egr*
After I am done I think that I will need to clear the codes out. If not that is great but if I do I am not sure how to.
Thanks,
Ed
Old 14 Nov 2010, 11:01 am
Default Re: Clearing codes.
Ed, welcome to the forum.
Any scanner can clear the codes but if you want to do it yourself, take the air filter off to get access to the battery. Take the negative battery cable off for about 5 minutes. That will clear any codes stored. While your there, check both cables for any corrosion that might be building up on the cable ends. Make sure both ends are good and tight and clean when you put it all back together.
Old 14 Nov 2010, 11:10 am
Thanks for the info. I was hoping the battery disconnect would work. I do not have the code reader to clear it out that way.
I have a friend who is divorced and she does not have the $$ to pay mechanic labor so I try to do her maintenance and minor work for her.
This site is great and I appreciate your reply and the others who take the time to help everyone out here.
Old 14 Nov 2010, 11:21 am
Lots of very friendly folks on the forum and always willing to help out. A thank you like you just posted goes a long way towards keeping the answers going out to owners with problems.
Old 05 Sep 2012, 08:10 am
Hello:
Just 5 minutes with negative out and error codes disappear?
PT Cruiser 2001 ECC engine 2000
Old 05 Sep 2012, 06:44 pm
mdfrodolives's Avatar
Step on your brake, too. It takes any residual power that hangs around to haunt you.
Tim
ribadiesel likes this.
Old 05 Sep 2012, 06:50 pm
Originally Posted by ribadiesel View Post
Hello:
Don't forget one thing. After the battery is put back together, if the problem still exists that made the fault light come on in the first place, it won't be long before the lights comes back on with the fault.
Clearing fault codes thender Tech & Performance Forum 2 08 Nov 2009 08:00 pm
obd-II codes Punch General Turbo Discussions 13 06 Jul 2009 06:54 pm
No Codes?? BB General PT Cruiser Discussions 2 13 Aug 2005 08:25 pm
obd codes camarillogolfer General Turbo Discussions 5 06 Aug 2004 11:10 am
Clearing check engine light Blade Tech & Performance Forum 10 27 Mar 2004 01:48 am
