How to bleed coolant system on 2.0 PT Cruiser
Old 14 Nov 2010, 01:50 pm
Default How to bleed coolant system on 2.0 PT Cruiser
Hi, I am new to this forum as I just recently became a PT owner.
The engine is running very hot - the temp guage goes all the way up to just below the red section, and I then shut it down to prevent damage. Although the cooolant expansion tank is at the correct level, the water level at the thermostat housing / pressure cap is non existant when I remove the cap. I have filled with water a number of times, and even opened up the bleed screw to get rid of air locks, but to no avail. I would put in 4 liters of water, run it till hot, and when I open the cap again is has no water in it. I must have put at least 8 liters of water into the system, it it seems to miraculously disappear.
No water in the oil, no excesive water / steam out the exhaust, no water leaks anywhere and the engine runs evenly.
Where could the water go - is there perhaps a very special way of getting rid of airlocks in the system/bleeding?
Old 14 Nov 2010, 02:17 pm
Default Re: How to bleed coolant system on 2.0 PT Cruiser
Welcome to the Forum.
We here in the States do not have the 2.0 engine, but I would imagine that running the engine until hot and then using the bleed off screw would do the same as for our 2.4L engines.
The other thing is maybe one of the radiator fan speeds is no longer working. If you look under the Performance Section there is a Sticky: Removing the fan and housing 01-05 PT, it should tell you about how to check for the fan, ours is a two speed fan.
There is a couple of PT Clubs in the UK, they have the 2.0 and the diesel and may be able to help you.
Old 14 Nov 2010, 09:44 pm
Where could the water go?
I once owned a Saturn L100 that did the same thing.
The coolant would just disappear.
No leaks, no steam, nothing.
It turns out the L100's had very porous aluminum blocks and the coolant would dissipate slowly through the block without a trace.
Only way around was to keep adding coolant.
In my case I went through about 8 liters of mixed (50/50) coolant annually.
Lot cheaper then changing the block
Needless to say I did a lot of hunting on the internet to try and figure what was going on and I still have the pages bookmarked.
Here is an excerpt from one:
From the Saturn forum:
"GM for a while had issues with porous castings. A porous casting is where air is not evacuated from the metal poured in the casting. The tiny amounts of trapped air cause fluid leaks. It is sometimes referred to as metal or block porosity."
Maybe your PT has the same problem.
Please follow up and let us know your resolution.
Old 15 Nov 2010, 02:22 pm
8 liters per annum is a lot of coolant, but 8 litres in a matter of three days and less than 10 kilometers travelled?
Will advise what the problem & solution was, as soon as I find it
Coolant System Drain Plug Mansel Tech & Performance Forum 6 30 Aug 2015 04:34 pm
Coolant System Problem. PLEASE HELP!!!! cgrayflorida General PT Cruiser Discussions 2 24 Jul 2010 05:10 pm
Coolant sensor/fan system help please? swordfish Tech & Performance Forum 9 03 May 2010 09:30 pm
coolant leak, pressure in system RaceWilson Tech & Performance Forum 5 24 Feb 2010 08:07 am
How to Bleed thePower Steering System ptrican General PT Cruiser Discussions 1 17 Feb 2010 09:21 pm
