Rough idle and stutter under load - possible misfire.
Old 14 Nov 2010, 03:17 pm
Default Rough idle and stutter under load - possible misfire.
2000 2.0 Petrol PT - Suffering from stutter, and bad attitude under load. Problem solved with new ignition leads, plugs and a battery disconnect for 10 mins. From reading the forums the battery disconnect resets the ECU and the new leads seemed to solve the stutter. Parts used were Magnecor 8.5mm leads and Champion double platinum plugs from the PT Cruiser company - UK. Thanks to some of the posts on this site I was able to avoid some costly troubleshooting at the garages.
Does anyone have any opinions on Diagnostic tools (code readers) for the PT - do they help much with a troubleshoot with regard to saving on garage bills..?
Cheers
Old 14 Nov 2010, 04:30 pm
chris15's Avatar
Default Re: Rough idle and stutter under load - possible misfire.
GENERALLY speaking, code readers aren't necessary as we can derive codes straight from the ECU with the 'key dance'. Not sure if the 2.0 models have this ability, but look it up and try it.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Rough Idle/Missing Under Load Etc. MattTee Tech & Performance Forum 9 03 Oct 2012 07:51 pm
Rough idle Jcamden Tech & Performance Forum 0 29 May 2010 02:56 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
Hard Misfire Under Load plugs changed karterfred Tech & Performance Forum 11 10 Jan 2008 07:10 am
Rough idle PTPaul Tech & Performance Forum 1 17 Oct 2001 05:34 pm
