disc brake grind and buildup
Old 23 Nov 2010, 11:36 pm
Default disc brake grind and buildup
Just within the last 2 days my 04 turbo lite with ~67000 miles started making a brake grinding noise. At first I wrote it off as out of adjustment drum brakes, but today it was obviously coming from the right front. I took a look through the wheel and noticed something odd: on the right front rotor their is a lot of buildup of the pad lining, but it is only on the outer part of the rotor. I'm not really sure how to describe it, but if you move outward from the hub the rotor is half shiny silver, normal looking brake rotor, then half built up with brake pad lining.
I thought I'd ask here before I dropped the money on pads and rotors, is there some other known issue that could cause this?
Old 23 Nov 2010, 11:52 pm
Default Re: disc brake grind and buildup
Sounds like you need brakes.
When was the last time you had them done?
Old 24 Nov 2010, 12:08 am
I bought it about 9k ago, so I have no idea how old they really are.
It seemed pretty clear that the brakes needed to be replaced, I just don't want to miss a root cause.
Old 24 Nov 2010, 01:17 am
Is the build up on the rotors really half way down the rotor?
That's a mighty large area.
Is the build up actually stuck to the rotors or is it just brake dust you are seeing?
Is this build up on both drivers side and passenger side rotors or just one?
Could be you have a bad caliper or the caliper is not gliding as it should.
Compete rear disc brake set up Gregt503 Classifieds: Want To Buy 0 28 Dec 2009 01:54 am
Rear Disc Brake Conversion Badger Tech & Performance Forum 1 30 May 2008 12:13 am
Disc Brake Pads and Rotors . Rich Slider Tech & Performance Forum 18 13 Jan 2006 04:27 pm
REAR DRUM BRAKE TO DISC UPGRADE blue General PT Cruiser Discussions 18 04 May 2005 09:51 am
Disc Brake Upgrading Stephen R. Tech & Performance Forum 9 31 Aug 2002 12:08 pm
