Error Code: P0325 PCM Knock Sensor Circuit
Old 25 Nov 2010, 08:55 am
Default Error Code: P0325 PCM Knock Sensor Circuit
I have this error code. What does it mean and how do I fix it??
Old 25 Nov 2010, 09:17 am
Default Re: Error Code: P0325 PCM Knock Sensor Circuit
Found this on an older thread:
P0325 OBD-II Trouble Code
Technical Description
Knock Sensor Circuit Malfunction
What does that mean?
A knock sensor tells the engine computer when one or more of your engine's cylinders are "knocking", that is, exploding the air/fuel mixture in a way that delivers less power and can be damaging to the engine if prolonged. The computer uses this information to tune the engine so that it doesn't knock. If your knock sensor wasn't operating properly, so that it was always indicating a knock, the engine computer's response may have been to change the ignition timing on your engine. The knock sensor generally threads into the engine block. This P0325 code may show up intermittently or the Service Engine light may be lit constantly.
Symptoms
You may notice drivability problems including a lack of power and perhaps some hesitation. There may also be other symptoms.
Causes
A code P0325 most likely means one or more of the following has happened:
* The knock sensor is faulty and needs to be replaced
* There is a wiring short/fault in the knock sensor circuit
Possible Solutions
* Check the resistance of the knock sensor (compare it to factory specs)
* Check for broken/frayed wires leading to the sensor
* Replace the knock sensor
P.S. Don't forget, you have a major maintenance requirement due NOW. Your timing belt and water pump should be changed at or before 100K miles or you'll be coming back again asking why the your PT won't start.
Old 25 Nov 2010, 09:56 am
Where do I find it and how do I get to it???
Old 25 Nov 2010, 10:19 am
I only have the manual for the 01-03 cruisers so I don't know if they changed the location in later years. They did change the location of the Crankshaft sensor in 04.
The Knock Sensor is threaded into the front side of the cylinder block, near the starter. Remove the battery for access.
Old 25 Nov 2010, 10:27 am
Oh Yea, no need to say THANK YOU. You haven't said a word on the first 5 questions you posted on the forum.
Remember these:
How to adjust the idle?
Rough idle with A/C on?
Best grade of oil after 100K?
Crack in body paint?
What else besides ATF+4?
Old 25 Nov 2010, 01:03 pm
Well let me say thank you.
You have given me lots of helpful advice including this thread.
Causes
This sounds like the problem I am having too, although I do not have a code.
However I will check the wiring tonight.
Thanks again Crewzin !!
Old 25 Nov 2010, 01:22 pm
Your welcome Bob. Hope it turns out to be the answer to whatever problem your having.
Old 30 Nov 2010, 05:20 pm
Jaguar's Avatar
Hi Crewzin,
This procedure to remove the knock sensor is the same for the PT Turbo 2003?
I a PT cruiser from mexico, My PT have a stage 1 and magnaflow catback and in high speed a knock noise is heard "cla cla cla" I changed the fuel pump, my PT used premium fuel, but I only need to change the knock sensor.
Regards from Mexico
Old 30 Nov 2010, 06:32 pm
Jaguar,
The book I took the picture from is for both the Turbo and Non-Turbo engines. If there was a difference they should have put two different pictures.....and they didn't, so I would think that the knock sensor is in the same position for both vehicles.
Old 30 Nov 2010, 11:37 pm
The knock sensor is also in the same place on a non-turbo 2006 if anyone is looking for it.
On my 2006 it is easier to access it from below.
PCM Knock Sensor Circuit?????? turbonate2003 General Turbo Discussions 11 19 May 2011 06:52 pm
P0325 Error Code Mikelowe93 General Turbo Discussions 8 25 Oct 2008 10:19 pm
P0325 Engine Error Code on 2003 PT Turbo intim3 General Turbo Discussions 0 12 Aug 2007 08:06 pm
error code p0325 pcm know sensor circuit madchildptgt Turbo Performance 1 20 Feb 2007 09:46 am
error code p0325 pcm knock sensor circuit? madchildptgt Tech & Performance Forum 0 16 Feb 2007 06:16 pm
