engine light on
Old 25 Nov 2010, 09:48 am
Default engine light on
doing the on off on off on function i came up with 2 codes.
p1684 which read was battery been changed or disconnected within the last 50 starts/ it had been so that wasnt a problem
p0551 which has come back as power steering sensor of somekind but what is it and is it serious.
ive only just bought the car less than a week ago any help is welcome
cheers
ric
Old 25 Nov 2010, 10:57 am
Default Re: engine light on
Power steering sensor switch. Not expensive, easy to get to and change BUT a very messy job. Fluid comes out faster than you can replace the switch. You need to have extra ATF+4 steering fluid to replace what goes all over the place (you and the ground).
Old 25 Nov 2010, 11:32 am
cheers fella
ill have a look at that in the morning its cold over here in the uk
will i have to pop to the dealer to get the engine light back off when its done
ric
Old 25 Nov 2010, 11:35 am
Ric,
You can turn the engine (fault) light off and clear the computer by taking off the negative battery cable off for about 5 minutes.
P.S. Spent 12 years in Harrogate. Wife is British and son born over there. Consider it my second home. Cheers.
Old 26 Nov 2010, 05:11 am
cheers fella
Will taking the terminal only cure the light problem for awhile thou
Old 26 Nov 2010, 05:58 am
Yes, but If the fault at the switch is real, it will come right back.
Old 26 Nov 2010, 07:26 am
Sorry dude what i meant was after ive fixed the switch will taking the terminal off only cure the light for awhile, also is this a serious problem as my local dealer cant get the part for 2-3 days is it safe to drive with this problem still.
Old 26 Nov 2010, 03:32 pm
I'm not a mechanic but I would say your safe to drive it for a few days. Second, if you replace the switch and take the negative battery cable off for a few minutes to clear the code, it shouldn't come back on.
Old 26 Nov 2010, 03:58 pm
cheers fella
Old 05 Dec 2010, 02:44 pm
CREWZIN
I've recently changed my battery. Yep, engine light came on. I 've been told by a mechanic that it's the power steering pressure switch (P0551)........................nope, they are wrong. Checked myself..............it's CODE 1684 "battery diconnected within the last 50 starts." Tried battery disconnect, key manipulation, and several resets. However, light returns. And, when I check for a problem, all codes show "no malfunctions." Any suggestions for a premanent reset solution?
Shannon T. Sommeling
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Engine light ejstith General PT Cruiser Discussions 25 18 Sep 2010 12:46 pm
engine light lostinoregon Tech & Performance Forum 4 08 Apr 2010 10:35 am
Engine Light ON AkiraCruiser Tech & Performance Forum 9 09 Apr 2009 09:54 pm
Car Sometimes won't start (oil pressure light & Engine Light) gerardio Tech & Performance Forum 6 18 Jul 2008 08:22 am
