error code o301
Old 25 Nov 2010, 02:50 pm
voorthuizen's Avatar
Default error code o301
Hello ,
Today I got the engine light on , checked the codes and got the code 0301 and that is misfire detected in cyl 1 , the car isn't running fine
does someone know what can cause this
thanks , Eddy
Old 25 Nov 2010, 03:16 pm
Default Re: error code o301
Eddy,
A bad spark plug or plug wire or fuel injector can cause the fault. When was the last time the plugs and wires were changed?
Old 25 Nov 2010, 05:18 pm
Thanks Crewzin , about 7000 miles ago I changed the plugs and the wires (8,5 magnecor) next Saturday I wil change plugs for Irridium ones and will test and clean (ultrasoon ) the injectors , so I will see of that helps
thanks again
Old 25 Nov 2010, 07:59 pm
Take the negative battery off to clear the codes. If the same code comes back, switch plug or wire Number #1 with another plug or wire and see if the code changes.
Old 27 Nov 2010, 12:50 pm
Today I changed the plugs for new ones and all looks fine , could't see anything wrong about the plugs though , thanks for helping out
Old 27 Nov 2010, 01:44 pm
Your welcome.
You can't see anything wrong with wires also (most of the time) but it's what's inside that counts. Hopefully your problem won't return.
Error Code bus b8 or 68, not sure. richardbradley Tech & Performance Forum 2 18 May 2010 07:45 pm
error code... superpug666 Tech & Performance Forum 16 13 Oct 2009 07:33 pm
Error Code saldagus Tech & Performance Forum 2 25 Nov 2008 09:51 pm
CPS Error Code smokeydan1 Tech & Performance Forum 16 23 Sep 2008 09:58 pm
Error code?? whiteknight Tech & Performance Forum 3 15 Mar 2008 10:29 pm
