Whining / grinding noise.
Old 27 Nov 2010, 02:56 pm
Default Whining / grinding noise.
Ok so the car has a recently replace water pump , timing belt etc.(2-3months ago)
Well now it is making a noise that sounds kind of like a bad power steering pump , but the noise does not get louder as you turn the wheel like any other bad pump I have ever heard , it is def. on the accessory side of the motor.
The noise was coming and going but today I guess the cooler weather the noise has be pretty much constant .
Any idea's ? It almost sounds like a bad bearing (standard not motor or cam).
I am lost , an after recently having the water pump , etc fix I do not have the money to take to some where...
Any idea's ?
2003 PT .. Stock besides tint an audio.
Pioneer 8600
Suprisingly crisp stock mids/highs (for now).
2 - image dyamic ID 8's
1.8 cubes tuned 30hz
Old 27 Nov 2010, 03:27 pm
Default Re: Whining / grinding noise.
That kind of noise could be coming from the right front wheel bearing and would make it sound like the accessory side of the motor.
Old 27 Nov 2010, 04:42 pm
Thanks , Guess I should have specified that it also does it when the car is in the standstill poistion & the noise does increase with rpms.
Pioneer 8600
Old 27 Nov 2010, 05:06 pm
mityqwik's Avatar
i had my timeing belt replaced about 5 months ago and water pump and pullys after a month went by i had a whinning noise also so i replaced the belt tensioner , serpenten belt and alternator belt,, dont know witch one took care of the noise but its gone
Old 27 Nov 2010, 05:32 pm
You know I keep telling myself that it is the tensioner bear , because it sounds very similar to the one I just replaced on my aunts dodge truck not long ago , but then I keep second guessing myself. I wish I had the spare money to just replace it an the belts just to see if that is it , I just dont have that kinda spare cash at the moment or else I would.
Kinda trying to find out exactly what it is , but I will have to get the car on ramps an start it an get under it to see if I can pen point the problem.
Pioneer 8600
Old 27 Nov 2010, 07:20 pm
Well whatever it was let loose tonight , an I have no power steering..
So I guess I will have to see what it is in the amp , cause no way I can dig into it tonight. Hopefully it wont hurt anything but my arms driving it to pick my wife up from work tonight.
Pioneer 8600
Old 27 Nov 2010, 09:30 pm
mityqwik's Avatar
from what you wrote it sounds like the serpenten belt,it runs the power steering and a/c and of couse the belt tenshener is also part of this i hope its a easy fix for you keep us posted here
Old 27 Nov 2010, 10:43 pm
after some inspection the belt the runs the a/c , p/s , is MIA , And the plastic pulley appears to be seized, I have found one for $23.99 at the local auto parts store. So hopefully the one store that says they have it in stock , actually will have it .. an hopefully that was the source of the noise.
Pioneer 8600
Old 28 Nov 2010, 12:59 am
mityqwik's Avatar
Thumbs up Re: Whining / grinding noise.
i hope that is it , would make repaires a lot easy,, on mine i searched around the local auto part stores because all i wanted was the pully on the tenshioner and NAPA was the only one that carried it and it is easier to replace than the whole thing ( i could not get a wrench or my hand up there to take the whole dam thing out) if i remember correctly.the new belt i got was a mopar belt but after a month it made noise so i got another from NAPA ( DAYCO belt and it has been quite since ) keep us posted let us know how it works out
Old 28 Nov 2010, 10:51 am
Thanks , will do going to try an get to work on it here shortly.
Pioneer 8600
AC Fan grinding noise shonenknife Tech & Performance Forum 6 27 Jun 2013 05:59 pm
Grinding noise. PtOnAir Tech & Performance Forum 6 10 Jan 2011 09:40 am
Another Grinding Noise... bjagd02 Wheels, Tires, Suspension 3 01 Nov 2010 09:01 am
whining noise coming from car? feefeethaflee Tech & Performance Forum 14 14 Feb 2010 10:50 pm
Grinding noise SmittysGold Tech & Performance Forum 21 20 Oct 2008 07:25 am
