How do I replace my alternator?
Old 28 Nov 2010, 02:12 am
Default How do I replace my alternator?
I have a 2004 turbo with just under 28K miles. The alternator (I think) has started "chirping". How do I replace it? Could it be a tensioner I am hearing?
David.
Old 28 Nov 2010, 06:58 am
garyerrol's Avatar
Default Re: How do I replace my alternator?
Personally, best thing to do if the alternator is bad is to take it to a trusted mechanic and let them change it out for you, unless you have the tools and expertise to remove and reinstall the passenger side drive axle.
Rebuilt alternator was something around $125, cost to have it installed was another $150.
2001 LE, Shale Green, Aftermarket Wheels, Shorty Antenna, AirRaid Cold Air Intake, Whelen Talons (amber/white) in front windshield, Whelen Talons (amber) in rear side windows, Tomar RECT25's (amber) and Whelen Slimlighter(amber) in back window. Kenwood TK-880H 45 Watt Mobile Radio, Antenex 3db antenna w/ NMO mount.
http://smg.photobucket.com/albums/v7...0PT%20Cruiser/
Ham: N9PTC
GMRS: WPQS324
Old 28 Nov 2010, 08:04 am
The alternator has it's own belt and tightening system. The "chirping" could be that the belt needs tightening. There's no tensioner for that belt. Is the battery going dead? Is there an engine fault light coming on. Don't go buying a part until the noise is diagnosed. As Gary pointed out, take it to a mechanic to find the real problem.
Old 29 Nov 2010, 11:13 pm
if you have access to good tools and work space the job can be accomplished at home. You will need to remove the passenger side drive shaft in order to remove the alternator from the vehicle. The alternator is removed through the bottom of the vehicle once the drive shaft has been removed.
03 gt with bad alternator jacarc1 General Turbo Discussions 5 31 Mar 2010 03:47 pm
H/O Alternator jonnbr Sound and Security Forum 0 18 Nov 2009 02:08 am
alternator hillbilly678 Tech & Performance Forum 4 05 Nov 2009 02:51 pm
alternator? DARK270 General Turbo Discussions 13 07 Mar 2005 02:27 am
Alternator Mark Tech & Performance Forum 0 13 Feb 2002 05:46 pm
