2005 PT problems any thoughts
Old 28 Nov 2010, 06:12 pm
Default Is it possible all at once? Any advice
The engine light came on car stalled, started after 2 or 3 min wait drove car to dealer to get checked out. They say I need a cam shaft sensor, crank shaft sensor, power steering switch would all be out of pocket and 2 burnt valves replaced which would be covered under power train warranty. Any thoughts I replaced the cam shaft sensor and knock sensor in June of 09 is it possible all of the above items need to be replaced?
Old 29 Nov 2010, 11:03 pm
Default Re: 2005 PT problems any thoughts
the sensors i can maybe buy if they provide a detail report from the diagnostic scan. However I would love to know how they diagnosed the 2 burnt valves, did they use a bore scope to check them or disassemble the engine?
For all of the sensors to fail at once without warning would indicate to me there maybe a bigger problem lurking.
Old 30 Nov 2010, 08:24 pm
I will ask about the valves, since they were under warranty they are being replaced for a $100 deductable Iím also replacing the timing belt for $ 91 which I felt was a fair price. As far as the sensors go I will replace them at home if the car is running poorly. The car didnít act like it did last June when I had to replace the Knock and Cam Shaft sensors the car only has 54000 miles on it and its not hard driving Iíll keep posting what I find out.
Thanks for the input.
Old 30 Nov 2010, 09:31 pm
Dino's Avatar
Your replacing the timing belt with just 54000 miles? Sensors usually don't go at the same time and usually don't have to be changed very often if you already did the cam sensor last June. Ask for the engine light codes that they got to determine these problems.
Old 30 Nov 2010, 10:02 pm
Iíll ask for the codes when I talk to them tomorrow, I figured I would change the timing belt because the engine is apart and I thought $91 was a bargain as far as dealer prices go. I did request the old parts Iíve never seen burnt valves. Thanks for the input
Old 01 Dec 2010, 08:17 am
Yes, $91 is a steal - I'd have water pump replaced - which is usually done when timing belt is done, again, because of the labor involved.
When you replaced the sensor a while ago - was it a Mopar sensor? It has been proven that as far as sensors go, it's safer/better to go with factory ones - some aftermarket ones have short lives, some don't work at all....
Old 01 Dec 2010, 10:44 pm
Picked up the PT from the dealer today with a few questions, the mechanic had left for the day but his notes revealed the codes were crank, cam shaft sensors and power steering pressure switch along with multiple cylinder misfire. He preformed a compression and cylinder leak down test. Cylinders 2&3 had less than 90psi of compression. He replaced 8 valves & lapped all other valves upon reassembly he noticed the water pump was leaking and replaced water pump, installed the new timing belt, added Freon topped off all fluids and road tested. I ended up paying for the timing belt P S pressure switch and $100. Deductable hard to believe they covered the water pump under the power train warranty but they did. Last June I replaced the crank sensor with an off brand than after reading this form and with a lot of friendly advice replaced the cam shaft sensor with an OEM sensor thatís all ill use from now on. Iím really thankful for the knowledge and advice thatís shared on this form itís a real PT family.
Old 01 Dec 2010, 10:54 pm
wow I am glad you got all the work done for such a cheap rate and under warranty. I am concerned by all the damage to engine with only 54,000 miles on it. I would dig a little deeper to detemine the root cause of the burnt valves, at 54k this should not be happening. The engine maybe running lean on those 2 cylinders.
As a side note compression test is used to determine ring wear, a leak down test determines valve leakage. You mentioned the compression test showed 2 cylinders low and not the leak down test.
Old 01 Dec 2010, 11:23 pm
Sorry I was going by his notes Iíve never done a compression or leak down test myself but now I know what their for. When he says he lapped the other valves did he just tighten the valve?
Old 02 Dec 2010, 05:03 pm
Lapping is a very mild grinding that makes valves seat better.
Any thoughts on the E3 Plugs ? 1lowufo Tech & Performance Forum 11 27 Aug 2010 05:48 pm
Thoughts on DexCool bobdole369 General PT Cruiser Discussions 2 27 Jul 2010 05:43 am
2005 PT Turbo Convertible Problems tempter805 Turbo Performance 2 23 Jul 2010 09:01 am
Thoughts: 06 VS 04 PT purple04 General PT Cruiser Discussions 11 11 Feb 2007 10:12 pm
steering problems: 2005 convertible bobsackaminnow PT Cruiser Convertible Forum 0 13 Sep 2006 06:56 pm
