Transmission leak
Old 30 Nov 2010, 04:22 pm
Default Transmission leak
Hi, I own a 2001 pt cruiser with 103k miles on her. In the past month I have realized I have a transmission leak so I brought it to a local ammco who insists I need an entire new transmission because something (he can't seems to even guess what) is wrong inside my transmission. My question is is it possible to replace the seal where the transmission buts up to the engine without changing the entire transmission?
Sadly I get the impression that being female I wouldn't understand and he would not tell me the technical name of the seal but instead would explain it is the seal between the engine and the transmission that is visibly leaking.
Thank you in advance for your help,
Carrie
Old 30 Nov 2010, 05:19 pm
cruserdad1976's Avatar
Default Re: Transmission leak
yes you can replace the seal between tranny and the motor
you can also replace the seal on the tranny pan
But if it is your rear main seal then it is usally gonna be your pump and then its just best to do the complete job
at 102xxx its not that uncommon but some have went a lot farther.
did you ever have the tranny flushed??? does the tranny slip??? shift hard??? miss gears???? a lot of city driving? highweay miles? if it is just a leak then you might be lucky and just need a seal replaced there are several that can leak on the PT
a tranny job is usally n the teens depending on where you are located
Old 30 Nov 2010, 10:48 pm
I have to agree with cruserdad that it is possible to replace the seal on the transmission pan and I think it is an easy fix to do. I suggest replace the seal first then observe it within a week and see if the leak still exist. If there is still leak, I think it would be best to bring it to workshop to have it check if it is really needed to replace the entire transmission. Hope this helps.
Old 30 Nov 2010, 10:51 pm
mdfrodolives's Avatar
Encara, take the PT to the dealer. A leak is just a leak. Maybe it's just your auto solenoid seal (above the transmission .... mine leaks a little). Or if it is another seal, that's all that needs doing.
Some of these mechanics are like people who work on your home heating/airconditioning systems. You call them for a small problem--and they will tell you that you need a whole new system.
Take it for another opinion--and don't mention anything other than a leak ... unless, of course, you have other transmission problems.
Tim
Old 01 Dec 2010, 11:02 pm
agree with the above the soleniod gasket is a prime leaker on these transmissions. The location of the solenoid block is also in such a position that if the gasket leaks the trans fluid will run down between the engine and transmission and all the way to the back of the transmission and make it look like a seal between engine and transmission has failed. A leaky solenoid gasket will usually coat the underside of the structural colar between the engine and transmission in oil.
The fix is not to difficult, 3 M10 bolts and a $4.63 gasket from your local dealer and of course a weekend to take your time and do the job right. Get a service manual and read through the replacement proceedure then decide if you want to attempt the job or not.
Old 01 Feb 2013, 06:31 pm
I just did an oil change on my PT today and noticed some seepage around my oil pan gasket, transaxle seal, and what I believe to be the solonoid gasket. I feel alot better now because now I know why I had to add half a quart of oil every 1,500 miles and a cup of ATF. I'm not going to replace the seals until it gets to the point where the fluid levels won't stay within a safe range.
2008 PT Cruiser Touring 135,000 miles
Old 01 Feb 2013, 07:15 pm
VNT's Avatar
VNT VNT is offline
Could be pan seal, axle seals, solenoid gasket, leaks with the hoses etc
Dont run it low on fluid, take it to dealer and have them look and check fluid level.
VNT
89 Shadow ES 2.5 T2 +20's A555 sold
90 Daytona ES 2.5 T1 A523
90 Datyona Shelby VNT needs work
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
03 PT GT Black 5 sp Stg 1
05 PT GT Silver 5 Spd Conv
Tags
transmission leak, transmission pt cruiser
transmission fluid leak joeus Tech & Performance Forum 11 11 Jul 2013 09:18 am
Transmission fluid leak tryanmax Tech & Performance Forum 19 22 Jul 2012 02:16 pm
Transmission leak!!! Milowe General PT Cruiser Discussions 1 17 Jun 2008 03:44 pm
ATF leak? calicranberry General PT Cruiser Discussions 7 19 Jun 2005 12:00 pm
Transmission leak macster Turbo Performance 17 25 Jan 2004 05:38 pm
