O2 Sensor - broken but no code?
Old 02 Dec 2010, 11:58 pm
Default O2 Sensor - broken but no code?
Just had our 2005 PT serviced after some misfire and acceleration/hesitation probs. The mechanic says the O2 sensor has shown up as not working on their diagnostic test but it has not/never has shown an error code on the instrument panel?
He estimates NZD$250-300 to replace incl labour. (USD$ 185-225).
I did a search and read about removing the negative lead for 10 mins. Is this worth a try?
Finally, what would be the 'typical' effect on a PT with a dud O2 sensor?
Thanks in advance.
Old 03 Dec 2010, 08:03 am
Default Re: O2 Sensor - broken but no code?
He wants HOW MUCH to replace the 02 sensor?
I'd find another mechanic fast. This guy wants to take a vacation with your money.
You have two 02 sensors. One right in back of the engine near the exhaust header (you can see it if you look down in back of the engine. Silver thingy plugged into the exhaust manifold with 4 wires coming from the top. The other right by the catalytic converter. Neither takes that much time to replace by any decent mechanic and the parts aren't that expensive either.
Failures of the sensors? Read here:
A dead sensor will prevent the onboard computer from making the necessary air/fuel corrections, causing the air/fuel mixture to run rich in the "open loop" mode of operation, resulting in much higher fuel consumption and emissions.
An additional consequence of any oxygen sensor failure may be damage to the catalytic converter. A rich operating condition causes the converter to run hotter than normal. If the converter gets hot enough, the catalyst substrate inside may actually melt forming a partial or complete blockage. The result can be a drastic drop in highway performance or stalling because of a buildup of backpressure in the exhaust system.
Old 03 Dec 2010, 04:49 pm
Thanks for the info and heads-up on the price.
Just went on-line and I can land a good quality Bosch sensor here in NZ for under USD$50!!
I will be asking the Dealer about his pricing in about 30 mins time
Cheers
P0340 cam sensor code in 2006 cruiser deighter Tech & Performance Forum 13 12 Jan 2012 07:41 am
upstream o2 sensor and code p0132 wingman1861 Tech & Performance Forum 5 27 Oct 2009 06:04 pm
Code 340 Camshaft Position Sensor kghaddon Tech & Performance Forum 5 08 Jun 2009 09:09 pm
Cam Sensor code changed sensor still dead RottenKid Tech & Performance Forum 8 18 Nov 2008 08:17 am
MAP sensor & code 108 twoyacks General Turbo Discussions 0 13 Sep 2008 05:51 pm
