Problem with heater
Old 03 Dec 2010, 01:18 am
cllwyrc's Avatar
Default Problem with heater
The heat in my pt cruiser does not stay warm for very long, it will keep going from cool to warm after car is up to running temp & even does it going down the road. At first the coolant temp would fluctuate but I changed the thermostat and now its just the heat. Is there an air pocket or do I need to replace the heater core?
Old 03 Dec 2010, 07:43 am
Default Re: Problem with heater
Did you bleed the coolant system after the thermostat change? You probably do have an air pocket and it needs to be bled out.
Old 03 Dec 2010, 01:32 pm
cllwyrc's Avatar
Whats the proper way to bleed the air out. I did bleed it a little bit afterwards but I don't know the proper way of doing it.
Old 03 Dec 2010, 01:45 pm
OK so you know where the bleed screw is since you say you did a little.
Radiator cap off, fluid right to the top. Fill the overflow container near the firewall, right up to the COLD line. Radiator cap back on. Unscrew the bleed valve till no air comes out, tighten valve.
Next: Use extreme caution, everything will be HOT.
Turn the engine on and turn the heater on and wait long enough for the water to get warm and the thermostat to open. Open the bleed valve again and see if there's any air coming out, if it's coolant or when the air stops coming out, close the valve.
Wait another few minutes and repeat the procedure above. Again, be careful, it's HOT.
Heater Problem!! m110pcon Tech & Performance Forum 14 01 Jul 2012 11:33 am
heater controls 4b316 Tech & Performance Forum 1 11 Jul 2009 07:25 am
Blower Heater Problem Phewzd Tech & Performance Forum 1 14 Jan 2009 02:45 pm
Block Heater, Rad Hose Heater, Which?? kb0nly Tech & Performance Forum 13 23 Dec 2008 03:47 pm
Heater problem dwallace PT Cruiser Convertible Forum 16 15 Jan 2008 08:23 am
