lost third gear ????????
Old 03 Dec 2010, 01:27 pm
Default lost third gear ????????
When i was driving around today i lost the third gear.
Its just like it is in neutral.
All other gears are working like they should.
I am driving a 2003 Base PT with manual transmission.
I hope someone can tell me wat is going on in my gearbo
Camiel from Holland
Old 03 Dec 2010, 10:38 pm
ProDigit's Avatar
Default Re: lost third gear ????????
I presume you have a Manual Transmission?
maybe one of the bushings, is your gearstick feeling loose? (you should be able to manouvre the stick about 1 inch without getting friction, any more may be a bad bushing).
I have the same in reverse. Sometimes I need to hard-slam the gearstick into place for it to work.
Still haven't figured out why.
I also notice on my PT2003, MT, that at certain speeds certain gears are blocked. Any speed above 20mph blocks me from entering into the first gear.
Old 07 Dec 2010, 01:41 pm
Thank you Pro Digit for your answer.
Yes, i have a manual transmission. And my stick moves about 1 inch when it is in a gear .It also shifts into a gear with no friction, just as it schould be.
The third gear is just like it is in neutral. Could there be a problem with the linkage to the gearbox ?
Camiel
Lost 3rd. Gear kingsfan General PT Cruiser Discussions 4 04 May 2010 07:55 pm
lost all car key outdoorbloke General PT Cruiser Discussions 8 15 Dec 2007 03:02 pm
p0733 Gear 3 Incorrect ratio p0733 Gear 3 Incorr RobGT General Turbo Discussions 12 04 Nov 2004 02:02 pm
New and Lost fy9-03pt General Turbo Discussions 1 26 Apr 2003 07:02 pm
