06ptidle and go problems
Old 03 Dec 2010, 09:35 pm
Default 06ptidle and go problems
hi my wife has a 06 pt with the 2.4auto nonturbO. we got it used with 49000miles. Recently it started being hard to start occ and rough idle and at30mph somtimes speed up and slow down.occ samE thing at 60 mph.
i see other appeaRS to have this same typE of problem and no shops cab fix it then what CHANGE WIRES PLUGS AND WIRESEVERYTIME IT HAPPENS ?/ THANKS
Old 04 Dec 2010, 08:00 am
Default Re: 06ptidle and go problems
What plugs are you using, what gap do you set them at? Are you using something other than stock wires?
Old 04 Dec 2010, 08:13 am
What are you using to type into this forum? You make it really hard to read with your spelling errors and mixing small and capital letters together on most of your words.
I agree with Hooligan, start with the basics. When was the last time the plugs and wires were changed. That's the first thing that you should do when buying a used car. Second is to check and possibly flush out all old fluids because you don't know what has been done in the past. Then you can be sure everything is done and keep records from that point on.
I don't go along with what you say that others have the same problem and they can't get it fixed unless they change plugs and wires everytime it happens. If it's done right, the problem won't come back.
Old 04 Dec 2010, 09:18 am
My typing is very bad it is called the hunt and peck system. No i have not changed the plugs and wires yet . That was next on my list of things to check i did put a good fuel add. in the gas last night. Thanks for all replies please continue to reply i need all the help i can get
problems with my pt DebbieRauch General PT Cruiser Discussions 2 12 Nov 2010 07:14 pm
Another new guy with fan problems. dangan General PT Cruiser Discussions 4 07 Jun 2010 10:41 pm
PT Problems... MrGrim General PT Cruiser Discussions 2 09 Mar 2010 09:59 am
DC3 problems alceryes General Turbo Discussions 5 09 Sep 2006 03:20 am
Problems Oddcouple General PT Cruiser Discussions 1 17 Nov 2002 01:58 pm
