02 PT engine cooling fan
Old 04 Dec 2010, 03:11 pm
Default 02 PT engine cooling fan
2002 pt cruiser. No engine fan. Results from some test are.
1 the fan will only work on high speed when direct current put to plug.
2 the feed wire to the fan gets hot (14v) but know fan at just over half way up on the guage.
3 the temp goes to red and still no power to the other side(high)
4 my fuses and relays are good.
What could keep the high side of the fan from getting power?
I realize I need to replae fan motor but I have read a lot of threads of ones that last 3-4 weeks, is there a good aftermarket fan motor?
Does anyone have a wiring diagram for this circuit?
Please help
Old 04 Dec 2010, 03:24 pm
Default Re: 02 PT engine cooling fan
See if this helps:
Old 04 Dec 2010, 03:32 pm
Wow, very good and very fast. Can you tell me where the pcm is located?
Old 04 Dec 2010, 03:42 pm
It's the square (about 8 inches square) black or silver box that connected to the firewall on the drivers side of the engine compartment. 4 red connectors on the PCM in the picture below. Not all of them have the 4 red connectors like you see there. Some have the connections at the bottom of the box.
Old 04 Dec 2010, 03:51 pm
Wow, I like your phot library. Any ideas on aftermarket fan motors? Rough cost of pcm?
Old 04 Dec 2010, 03:55 pm
PCM, re-manufactured somewhere around $300
Chrysler
The fans can be bought cheapest on eBay. There's hundreds of them and usually under $100. Really can't tell what country they are from or how long they will last.
06 07 08 PT Cruiser Radiator Condenser Cooling Fan Assy - eBay (item 270663472944 end time Dec-13-10 09:45:11 PST)
Engine is over....cooling?! ucantcme General PT Cruiser Discussions 24 23 Sep 2011 08:40 am
cooling fan r.p.m. priest Tech & Performance Forum 5 13 Sep 2010 12:26 pm
A/C not cooling at all bigjoe1651 Tech & Performance Forum 5 10 Oct 2009 02:42 pm
engine cooling motor wrinkles4u2 Tech & Performance Forum 0 26 Jan 2009 12:06 pm
A/C .. and Engine cooling fan mystery delbassman Tech & Performance Forum 9 02 Apr 2007 01:14 am
