cam sensor
Old 05 Dec 2010, 02:06 pm
Default cam sensor
Hello, I have a 03 pt non turbo and it wont start the check engine light came on the other then went off.
I had it towed to a shop, he said it was the cam sensor he said he would replace both of them for 283.00 ? is there 2 or 1
could I DO IT MYSELF fair with tools.
Thank You.
Old 05 Dec 2010, 02:17 pm
Default Re: cam sensor
Yes, you can do it yourself and there's only 1 Camshaft sensor. Even if you don't do it, stay away from whoever you talked to.
If you have any experience at all and some basic tools, you should be fine. It's located on the right side of the engine as your standing in front of it. Here's a HOW TO link ...
How to Fix the Camshaft Sensor on a PT Cruiser | eHow.com
One more thing. ONLY buy the Camshaft Sensor at a Chrysler dealer. A little bit more expensive than an auto store but worth it. Some after market sensors don't work.
Now, after saying all that, he might have been talking about the other sensor known as the CRANKshaft sensor. IF he's going to replace both (Crank/Cam) with Genuine Chrysler parts (tell him you want to see the boxes), then it's not too far out of line for your $283.00 with parts, labor and taxes.
Old 05 Dec 2010, 03:48 pm
Thank You, I just went and picked it up from the shop.
I messed with the wires and also unhooked the battery for a few min.
kept trying it and it started the check engine light was on all the way home 10 mi. Going to the parts store. Thanks for the help
Old 05 Dec 2010, 04:12 pm
Your welcome, good luck.
05 Cam Sensor cowboyinboxers Tech & Performance Forum 1 25 Jun 2010 03:41 pm
what is a MAP sensor? cruisergt General Turbo Discussions 18 27 May 2010 09:20 pm
ECT sensor manchadeplatano Tech & Performance Forum 6 06 Jan 2009 10:03 pm
Where to buy an IAT sensor? daki2886 Tech & Performance Forum 0 15 Dec 2008 04:23 pm
Cam Sensor code changed sensor still dead RottenKid Tech & Performance Forum 8 18 Nov 2008 08:17 am
