02 engine swap
Old 07 Dec 2010, 05:21 pm
Default 02 engine swap
My wife has a 02 PT. We found a engine late summer with 40,000 miles from a 03 at a body shop that takes 2 vehicles and makes 1. I asked if this would be the same as the 02 and they said it should. Some day I think I may be or should be scared of that word!!! I am in process tearing motor apart to change timing belt, that is when I see the other engine is not with EGR. Just being silly here, but could a guy bore a hole in the head to make it work? Bolt holes are there for egr, but no hole.
Old 08 Dec 2010, 05:26 am
1972cudaguy's Avatar
Default Re: 02 engine swap
You should be able to do that . I swapped a 2002 2.0 motor into my 1996 Neon , same thing had to drill & tap holes for EGR on the later one .
Old 11 Dec 2010, 12:44 pm
Thanks cudaguy. I have been looking it over and thank it is doable. It already has the bolt holes with threads, just no hole for exhaust to come out.
engine swap luckybadazzboy Tech & Performance Forum 16 11 Aug 2016 12:10 pm
engine oil pan swap cruizinla Tech & Performance Forum 2 13 Oct 2009 07:32 am
engine swap nimblemotors Tech & Performance Forum 10 01 Aug 2009 02:09 am
02-03 Engine swap brit Tech & Performance Forum 0 13 Apr 2009 12:49 am
engine swap INFERNODPPT Tech & Performance Forum 21 29 Oct 2005 10:00 pm
