Headlights dim and bright at idle...help!
Old 07 Dec 2010, 09:30 pm
Default Headlights dim and bright at idle...help!
I have an odd problem with my wifes PT,
It's a 2004 turbo,
At idle the lights will dim and brighten...this has been on going for at least a year and I figured it was the alternator trying to go out so I thought I will wait for it to go out before I fix it and it hasn't stopped working,
So help me out...do you tech heads believe it is the alternator or something else?
Could this be a bad ground issue?
Many thanks,
Cheers,
P.
Old 15 Dec 2010, 11:51 am
mikelikestobike's Avatar
Default Re: Headlights dim and bright at idle...help!
It's a 2004 turbo,
Many thanks,
Cheers,
P.
I'm having the same issue - '03 non-Turbo.
Anyone?
'03 Manual non-turbo in Silver w/ Factory flames.
K & N Drop in, Modded airbox, MSD Superconductor wires, Strut bar, blue dots in taillights. Sold 12/13
Old 15 Dec 2010, 11:54 am
veracruise's Avatar
I'm having the same issue too. 04 non trubo
Old 15 Dec 2010, 12:52 pm
I saw this on another forum as a flicker cure:
"I fixed mine a while back by simply pulling and cleaning the contacts on auto shut down relay in the fuse box behind the battery box. Its the relay in the upper left corner (as you face the widshield). "
Also - have charging system checked - places will do it for free - you could have a weak alternator
Be sure battery cables are clean and tight, and be sure grounds are clean and tight, and can't hurt to add a couple more cables from minus of battery. I ran one to engine block, and another to the computer housing on the firewall...
FACTORY BRAKE PEDAL PADS (bright) GT?? mjb457 Interior Accessories Forum 4 13 Oct 2010 08:27 am
ruff idle at idle only? KRNFIRE General PT Cruiser Discussions 16 23 Jan 2009 09:08 pm
Bright white bulbs turbomangt Exterior Accessories Forum 37 17 Jan 2005 11:23 am
Headlights mpython Tech & Performance Forum 4 30 Dec 2003 10:26 pm
