ptc won't shift out of low 0700 1684
Old 08 Dec 2010, 02:54 pm
Default ptc won't shift out of low 0700 1684
need cheap fix. PT won't shift...is auto trans...changed fluid and filter...getting codes 300 700 and 1684. any help appreciated. Stays in low. Very rough when shifting from park to drive.
Old 08 Dec 2010, 06:13 pm
BladeRunner's Avatar
Default Re: ptc won't shift out of low 0700 1684
P0300 is multiple cylinder misfire;
P0700 is transmission/transaxle controller.
P1684 is battery was disconnected.
Old 08 Dec 2010, 06:21 pm
The P0700 is what your interested in. It's a generic code for something wrong in the trans or modules. You have to have a scanner to localize where exactly the problem is. Not really any cheap fixes when it comes to the transaxle.
Old 10 Dec 2010, 09:38 pm
Went to AutoZone today. A retired mechanic working there said I'd probably need to change out the module on top-front of the auto trans. He also told me I might try taking a cable off the battery for a minute or so. I tried this while I was there...left it off for 2-3 mins...and walaah! When I started it up the check engine light was not lit and it shifted find!!! This is probably not a permanent fix, but its good for now, If and when I have I have shifting probs. or the engine light this will be the first thing I try. Keep cruising.
Old 11 Dec 2010, 02:13 pm
Make sure your tranny is full of fluid, I recently put a half can of Sea Foam trans tune up in. I noticed a difference almost right away,it's a cleaner and my high gear seemed to be "lazy" coming back in after the passing gear kicked in. I did have my trans flushed after a couple of days and now it's a little firmer in shifts and the "lazy" part is gone. This cleaner is meant to be used just before the flush,so don't use it as a permanent fix. It's NOT intended to be left in there.
Codes 1684 & 0123 - What did I do? EDGEFIND Tech & Performance Forum 11 18 Sep 2012 08:00 pm
Error Codes 301 & 1684 - Help? RainfirePT Tech & Performance Forum 3 19 Mar 2010 10:44 pm
Computer Codes 0455, 1781 and 0700 mannysan Tech & Performance Forum 1 15 Oct 2009 10:20 pm
Help needed for P 1684 code JazzeCouture General PT Cruiser Discussions 1 15 Nov 2008 02:07 am
Error Code 0700 on my 2001 PTC piccolo Tech & Performance Forum 1 30 May 2008 07:00 am
