getting a po300
Old 08 Dec 2010, 10:53 pm
veracruise's Avatar
Default getting a po300
Would this mean that the valves are missed up?
Old 09 Dec 2010, 07:17 am
Default Re: getting a po300
NO. When was the last time the spark plugs and wires were changed?
Old 09 Dec 2010, 07:43 am
veracruise's Avatar
I change the plugs last week, and the wires not to long ago.
Old 09 Dec 2010, 08:14 am
Did the code come on right after you changed the plugs and you changed the wires not to long ago without doing the plugs at the same time? Why was that?
Looking over your other threads, you've done some extensive work with the timing belt, the loose IAT sensor and cleared the codes with an OBDII sensor. How about using that sensor again to try and pinpoint your multiple misfire. Did you clean the little rubber gaskets on the upper intake manifold before putting everything back together? Did you torque down all the bolts on the manifold after the plug change?
Old 09 Dec 2010, 01:18 pm
veracruise's Avatar
No, the code did'nt come up until last night. The only code that did come
up was for the IAT. The P0300 just came up for the 1st time. The car is running
alittle rough at idle but when I give it gas it smoothes out like normal. I did put new
gaskets on the intake. Was I suppose to change wires everytime I change
the plugs?
Old 09 Dec 2010, 01:23 pm
No, the wires usually last a lot longer than plugs except for the wires that Chrysler uses from the factory. They are "crap" and need to be changed at the first plug change or sooner. As soon as any kind of trouble (hesitation, ruff idle etc.) comes up we always ask when the wires and plugs were changed.
Old 09 Dec 2010, 04:07 pm
veracruise's Avatar
I may go ahead and change the wires and see if it makes an differance.
And kinda look around the intake and see if find anything else. Thankk you Crewzin
ERROR CODE PO335 & PO300 - HELP! PTZIGGY Tech & Performance Forum 7 09 Dec 2009 05:53 pm
