No power steering.
Old 09 Dec 2010, 04:27 pm
Default No power steering.
So this last Saturday I'm running around in my wife's PT. It's a 01 base. It's about 20 degrees out side and we had about 4 inches of snow. I'm on my way home and I notice that the steering wheel is INCREDIBLY stiff. The PT is pointed straight a head and I've only got about a one to two degree rotation from the steering wheel. I had to do a slow 3 to 4 point turn to get it into the driveway. Fluid level is good, so I'm thinking it's hopefully one of three things.
Pump went bad.
Belt broke.
Something with the steering column.
Anyone have a similar experience? I haven't had a chance to look into it and hope to do some work on it this weekend before the snow gets here. Any thoughts?
Old 09 Dec 2010, 04:37 pm
Default Re: No power steering.
Yep, pump failed.
Old 09 Dec 2010, 04:45 pm
Sigh, not sure which would be worse to get at, the pump of the belt. Gotta get to the belt to get to the pump. Wish I had a garage I could get it into. Maybe I'll luck out and I can get the BII running and move it out of the way. I hate a single car garage.
Old 09 Dec 2010, 05:58 pm
Might as well change the belt also while you are in there, check your serpentine belt also.
Old 10 Dec 2010, 08:58 am
I purchased new belts this summer, just never got around to it. I'm thinking I might just go ahead and do the timing belt and water pump also, since I'm in the neighborhood.
Old 10 Dec 2010, 12:38 pm
cruserdad1976's Avatar
well that would be one heck of a big neigherhood the timing belt is like a 10 hour job but if you got that much energy get r don
Old 10 Dec 2010, 02:33 pm
Worth thinking about. Could get really crazy and finally replace the lower control arm bushing too. Most likely will stop at the pump. I still haven't looked at it yet, so I'm holding out hope that it's just a belt.
Old 14 Dec 2010, 10:10 am
Finally got around to taking a look last night. Just need to replace the belt, whoo hoo.
Old 20 Dec 2010, 12:13 pm
Well, I need a new tensor pulley. I'm trying to avoid the purchase of the whole thing, just the pulley. The bearings are frozen. Not sure if that happened before or after the plastic shroud burned up in the lower pulley for the power steering. Any idea of where just to get the pulley?
Also, how in the world are you suppose to get a wrench on the top alternator bolt to loosen it so I can put a new belt on?
Old 20 Dec 2010, 01:13 pm
mityqwik's Avatar
Thumbs up Re: No power steering.
i replaced my serpentine belt 2 months ago and the belt tenioner ( just the pully) only auto part store to stock just the pully was NAPA /while i was there i replaced the alternator belt,had to get the haynes book out for that one.its doable but a pain
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
power steering? PTcruzer02 Tech & Performance Forum 7 25 Feb 2012 11:39 am
Power Steering ? reklaweelmada Tech & Performance Forum 5 24 Dec 2009 08:08 pm
Help...No power steering scottw General PT Cruiser Discussions 17 21 May 2008 09:13 pm
Power Steering proxeyed Tech & Performance Forum 6 02 Mar 2005 09:55 pm
ATF + 4 or 5 for power steering? quicksilverdon General PT Cruiser Discussions 2 21 Feb 2005 05:00 pm
