Check engine light, lights flickering, backfiring HELP
Old 09 Dec 2010, 05:28 pm
Default Check engine light, lights flickering, backfiring HELP
My 03, 2.4 turbo check engine light just came on, the engine started running rough and backfiring. All the lights (headlights, dash, radio, etc) flicker. Checked all fluid and battery connections and they seemed fine. Any suggestions of what to look for that is causing the problem?
Old 09 Dec 2010, 07:04 pm
SCBluePT's Avatar
Default Re: Check engine light, lights flickering, backfiring HELP
You could try the key dance to pull the codes and go from there.
How to retrieve fault codes.
Old 15 Dec 2010, 11:36 pm
Thanks, pulled the code (p0301) misfire in cylinder 1. Replaced plugs and wires, run great.
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check engine Light atcaudill Tech & Performance Forum 22 22 Dec 2009 09:07 am
Check engine light just came on! lajag24t Tech & Performance Forum 22 13 Aug 2009 05:22 pm
Engine Check Light IRPT Tech & Performance Forum 11 27 Jun 2004 10:24 pm
CHECK ENGINE LIGHT MEXICANPT Stage Turbo Kits 3 08 Aug 2003 11:13 am
