Intake Manifold
Old 09 Dec 2010, 09:52 pm
WolfmanG's Avatar
Default Intake Manifold
Does anyone know if any one makes a performance intake manifold?
-Danny Wolfman G
Old 09 Dec 2010, 10:09 pm
Default Re: Intake Manifold
For the Non-Turbo? I don't think so. Chrysler did make a better one for the Turbo models but never changed the Non-turbo manifolds and the after-market never cam out with one that I know of.
Old 09 Dec 2010, 10:12 pm
WolfmanG's Avatar
Yeah that's what i though. Thanx Crewzin
-Danny Wolfman G
Old 11 Dec 2010, 10:58 pm
There are a few guys over at ptcrew.com thathave put the plastic turbo manifold on a NA and got a good improvemnt. Looks like is a fairly easy swap.
Old 11 Dec 2010, 11:37 pm
WolfmanG's Avatar
Thanx, i'll check it out. I just signed up.
-Danny Wolfman G
Old 12 Dec 2010, 01:35 am
chris15's Avatar
The 06+ plastic turbo manifold will bolt up to the N/A PT. It rectifies a lean condition in one of the cylinders by way of a diverter inside the plenum.
As I said in your thread regarding the larger TB: with a bit of work, you can modify an SRT-4 or an Indy intake manifold to fit. You'll have to lose the single fan on the inside of the radiator, but you can install a better-flowing fan or fans outside the radiator. You can even fit slim fans behind the stock grille. No issues. You'll also have to transplant your sensors onto the new TB.
Look up Alex (low_pt) on PTCrew and he'll give you answers.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 12 Dec 2010, 02:51 am
WolfmanG's Avatar
kool thanx.
-Danny Wolfman G
Old 12 Dec 2010, 05:05 pm
The lean condition was on the turbos with the aluminum manifold. The na plastic intake manifold is just fine. The runners on the turbo plastic intake manifold and the na plastic intake manifold are the same. I call BS on any gains with a na PT using a plastic turbo intake manifold. It's funny watching 2nd and 3rd generation PT owners making the same mistakes trying to increase performance in the na PT that the 1st generation owners did.
Old 12 Dec 2010, 06:38 pm
SCBluePT's Avatar
I didnt know there was a 3rd generation PT.
Old 13 Dec 2010, 04:57 pm
Here is a link to the guy that swapped an NA for a Turbo manifold.
PTCrew.com - Learn it or Burn it.
Intake Manifold turbo_pt2003 General Turbo Discussions 11 18 Dec 2009 01:51 pm
intake manifold??? PTcruzer02 Turbo Performance 5 26 Dec 2008 10:58 pm
Intake manifold discovering06 Tech & Performance Forum 1 26 May 2008 05:37 pm
New Intake Manifold Mel K General Turbo Discussions 2 20 Sep 2005 10:06 am
intake manifold milPT Tech & Performance Forum 5 24 May 2004 03:03 pm
