Error P0506
Old 10 Dec 2010, 07:09 am
Question Error P0506
I checked the error code on the sticky: low idle .
Does anyone have any ideas?
Thanks in advance.
Old 10 Dec 2010, 10:38 am
Default Re: Error P0506
The computer sets the idle however there's a few things that can cause the computer to throw that code.
A vacuum leak
An air restriction in the intake air path or exhaust
A faulty positive crankcase ventilation (PCV) valve
Damaged/failed/dirty throttle body
Internal engine problem
Failed PCM
Old 10 Dec 2010, 12:40 pm
cruserdad1976's Avatar
wow crezin none of them really sound all that good do they
Old 10 Dec 2010, 06:27 pm
Just the last two are bad. The rest are home mechanic type stuff.
I'd start by taking off the negative battery cable for 10 minutes. That will clear the code and computer. Then, if it comes back on, you can start trouble shooting what might be wrong. It might have been a one time fault that the computer got a message about and set the code. It might clear itself and then the light won't come back on.
Old 05 Jan 2011, 09:34 am
I reset the PCM via the battery cable method. I cleaned the throttle body and replaced the PCV about 5K ago (dealer part). This morning it was 24F and the CEL came on again with the P0506. When it gets below 30F the CEL come one with this code. Could it be the IAC?
Thanks
2006 PT touring edition, 5 spd manual, 140K, MSD 8.5 mm wires, Champion plugs
Error Code bus b8 or 68, not sure. richardbradley Tech & Performance Forum 2 18 May 2010 07:45 pm
error code... superpug666 Tech & Performance Forum 16 13 Oct 2009 07:33 pm
Error code 601 COOLSILVER02NV Tech & Performance Forum 7 14 Jul 2009 10:52 am
CPS Error Code smokeydan1 Tech & Performance Forum 16 23 Sep 2008 09:58 pm
Error code?? whiteknight Tech & Performance Forum 3 15 Mar 2008 10:29 pm
