02 front crank seal
  • 1 Post By spiral
Old 10 Dec 2010, 03:02 pm
Default 02 front crank seal
I am in the process of changing timing belt. I would like to change front crank seal. I see the crank gear has 3 bolt holes for pulling, does any one know what size of bolts and thread that it takes?
Also does it pull fairly hard, and do you need to press back on with crank bolt and a spacer, or is something I need a special tool for?
Old 10 Dec 2010, 06:14 pm
Default Re: 02 front crank seal
Don't know if it will answer your exact question, but here's a little to read. Scroll down to the part that has the replacement of the crank seal.
Chrysler Questions - 2005 PT Cruiser w/ 2 4L Had to replace the front crank seal - JustAnswer
Old 11 Dec 2010, 12:37 pm
Not quite what I am looking for. I think thread and hole size may possibly be a 6-1.00.
I do not believe seal is leaking but, why I was this close thought might be a good time to do it.
Old 11 May 2013, 03:23 pm
Thanks for your post. This was not an easy question to get answered. I am stuck myself on what bolts are used to remove the crankshaft timing gear so I can replace the crankshaft seal. I called my local after-market parts distributors and they didn't know. I called Chrysler and they didn't know either. Did the 6-1.00 work? I went through an extensive bolt collection and still couldn't identify the correct bolt and thread pitch. Thanks for any help you can offer.
Old 11 May 2013, 06:24 pm
Hi, I did it last weekend, I could not find bolts long enough so I bought a M6 rod and 3 M6 nuts, I cut it to 3 pieces 5 inches long. It did work well. Use air tools if you can.
Before removing the sprocket do not forget to measure its position on crankshaft (gap between the sprocket and engine block or length of the shaft from sprocket to the end)
Be careful with the sprocket key, it needs to be removed prior to seal replacement.
Good luck with your work.
Old 11 May 2013, 07:21 pm
Go to the how to section in the tech and performance section. Top of the page in the sticky. Go to replacing the timing belt. Scroll down to the harmonic balancer and crank sprocket removal and installation tips and tricks. Every thing you need is there. With pictures.
Old 12 May 2013, 05:22 pm
HARMONIC BALANCER & CRANK SPROCKET REMOVEL AND INSTALL TOOL AND TIPS!!!!
Old 12 May 2013, 08:20 pm
For some reason the link that Busted posted doesn't work.I used his post when I did my timing job and it worked GREAT!! I got the bolts at Fastenal.. I did however, have to rent the OEM puller for the crank pulley at Autozone.. I used PVC pipe instead of the metal pipe..Heres the bag that the timing gear bolts came in with the part number for Fastenal..They were a little long to pull the gear all the way off the crank, but I just stacked washers..
Busted_PT likes this.
Old 13 May 2013, 02:57 pm
Thanks for the help. I wanted to pay it forward, so I thought I would post the results for the next guy searching for an answer to this particular question. When changing the front crankshaft seal on a 2001 PT Cruiser, the bolt I used to remove the timing gear sprocket from the crankshaft was a M6-1.0x70mm (6-1.00) I had to buy them specially because they don't come with any of the gear puller kits I own. Chrysler couldn't even tell me what bolt threaded into that gear. I had to burrow one from one of my area dealer mechanics and run over to the local bolt store to match it up. Hopefully, this will save some other guy a few headaches. For the record, this is the worst car I have ever had to work on. It's fun, but not fun enough to forget about the pain in the butt it is to put a wrench to these.
Front crank seal oil leak Pt4Me General PT Cruiser Discussions 10 25 Nov 2012 03:27 am
New Car paint seal turbomangt The Detail Shop 2 12 Jul 2004 06:02 pm
New Poly-Seal is here turbomangt The Detail Shop 6 01 May 2004 12:14 pm
NEW POLY SEAL IS HERE! turbomangt The Detail Shop 2 23 Mar 2004 11:40 pm
Air Seal PianT Canada PT Forum 0 12 Dec 2003 01:25 pm
