Larger Throttle Body
Old 10 Dec 2010, 09:44 pm
WolfmanG's Avatar
Default Larger Throttle Body
Do you thinking adding one of these would really help with performance?
-Danny Wolfman G
Old 11 Dec 2010, 03:10 am
chris15's Avatar
Default Re: Larger Throttle Body
If you're N/A, nope.
If you're turbo, possibly.
If you use it on an N/A, you'll need to do a ton of work to figure it out as it's "Universal". You'll need to figure out your sensors, throttle cable, etc. Even if you find a way to link it up, you'll have issues with driving the car. It won't idle correctly for starters, and I can't even imagine what the PCM would do if it saw all that excess air without enough fuel to compensate.
If you're turbo, there are benefits to be had, buuuuut not with a stock intake manifold. The issue is that the opening on the plastic intake manifold (better design) is 56mm. So basically you're doing nothing by running anything higher than a 56mm TB. It'd be the equivalent of running a TB spacer. (Search if you haven't already)
The only way to make power with a larger TB is with a ported intake, and the correct adjustments made to compensate for the increase in flow.
A lot of the SRT-4 guys run larger TBs that bolt right up to their intake mani, but the bolt pattern is completely different than ours.
Only option is to attempt to retro fit an SRT or Neon-style intake manifold to your car. You'd have to lose the stock radiator fan and install a 'puller' fan in front of the radiator to replace it. It's a ton of work.
Short answer: not worth it.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 11 Dec 2010, 06:09 am
Kid, I believe that most of your posts have been asking about "add-ons" you could use to increase speed, performance etc.
You have to understand if you have a NA that it is about the best it will be, now you can change plugs, wires and intake filter, but that is about all.
You have a 3000 pound brick you are pushing down the road, it is NOT aerodynamic and is called a Cruiser not a racer. If you want more performance, sell it and get a Turbo, I just hate to see you spend money on snake oil parts. Enjoy the PT as it is.
Old 11 Dec 2010, 06:33 am
urimashe's Avatar
he is right you know..... or you can keep your pt and put in a turbo, but thats alota work. and money..... with all the sanke oil thou you keep getting it might not be a problem for you ^^
2006 Base PT Manual Tranny, K&N drop in filter, Marine Blue paint, Name: Blue Monster, Body style: Path Cruizer... oh yea, seat covers? got em.
Old 11 Dec 2010, 08:44 am
SCBluePT's Avatar
I agree,if you want more power trade for a turbo PT.Otherwise you are just wasting money on these gimmicks.
Old 11 Dec 2010, 06:42 pm
chris15's Avatar
Or, you can turbo yours like I did:
the axe effect
(^ Courtesy of Alex, low_pt)
Old 11 Dec 2010, 07:48 pm
WolfmanG's Avatar
lmao. that's true, i should just save my money and get a GT or turbo, but i know all the work that's involved.
-Danny Wolfman G
Old 11 Dec 2010, 07:49 pm
WolfmanG's Avatar
the axe effect
i've been thinking about that, and by the way, that looks beautiful.
-Danny Wolfman G
Old 11 Dec 2010, 07:53 pm
SCBluePT's Avatar
Just get a GT and you dont have to do any work.It will also have a stronger bottom end to handle the turbo.
Old 11 Dec 2010, 08:15 pm
WolfmanG's Avatar
I've been thinking about it, but it seems like the GT's are rare in San Antonio. I don't want to get rid of my Eve. I'm thinking of just buying a GT. But then again if i do get enough money to buy another car, i'll proly go back to building a muscle car or just invest into glamming up my PT.
-Danny Wolfman G
EGR and Throttle body pteezer129 Tech & Performance Forum 5 22 Jul 2011 02:28 pm
Throttle Body wiky86 Tech & Performance Forum 10 21 Jul 2008 09:59 pm
looking for a throttle body....................... rockrtboy Classifieds: Want To Buy 2 09 Jun 2007 11:44 am
FS: Stock GT Throttle Body FastNJPT Classifieds: For Sale/Trade 0 26 Apr 2005 12:28 pm
Throttle body spacer? 1lowufo Tech & Performance Forum 5 23 Mar 2005 09:50 pm
