Trac control system?
Old 14 Dec 2010, 08:29 pm
BladeRunner's Avatar
Default Trac control system?
OK, I have an issue with my trac system. I didn't notice it until we got cold & snow on the ground. When I get wheel slip the green trac light above the odometer flickers on & off quickly and I can hear rapid clicking under the hood, I'm thinking that's the trac trying to lock up...but it can't.
This happened a few times, if I switch it off the clicking stops right away. Now, the switch won't work & doesn't light up. I'm thinking the fuse has blown I just haven't checked it yet. so, is my trac system pooched?
Old 15 Dec 2010, 06:43 am
Default Re: Trac control system?
TRAC and ABS both make a racket and are almost the same thing....
There are speed sensors at the wheels, and the computer compares how fast left wheel is spinning versus right wheel.
TRAC : If one wheel is turning a lot faster than the other wheel, the brake on the faster wheel is applied for a split second, released, then the speeds compared again, and if the "fast " wheel is still too fast, brake applied again... - what you hear is the clacking of the brake on and off rapidly.
ABS comes in when you are stopping - if the speed sensors detect a wheel has locked, it releases the brake on that wheel for a split second...repeats...
In the dash you should always see TRAC if the TRAC is shut off -do you? If so, maybe just the bulb in the switch is burned out.
Old 15 Dec 2010, 07:01 pm
Thanks quicksilverdon; So that rapid clicking is normal? Sounds pretty nasty to me, it is a much higher pitch than the ABS..and WAY faster!
I don't see the trac light..no response from the switch..( not lit either) and makes no difference what way it's moved. The bulb in the trac (orange) does still work, I see it when I do the self diagnostic on the cluster.
So, just so I'm clear, the (green) trac light indicator does flicker quickly when it's working normally? Thanks..
trac control & abs light staying on in dash bobs turbo pt General PT Cruiser Discussions 13 22 Apr 2017 08:44 am
Trac control or ABS? sptanz General PT Cruiser Discussions 10 30 Apr 2012 11:07 am
Trac control kicking off E brake alarm? sknight88 General Turbo Discussions 1 05 Jul 2008 08:03 pm
TRAC system shodobe Tech & Performance Forum 2 31 May 2005 07:58 am
Trac control, wiper switches on center dash Espresso General PT Cruiser Discussions 6 04 Apr 2005 09:50 pm
