What exactly is a tune-up on a '07 Cruiser?
Old 15 Dec 2010, 07:20 am
falconut's Avatar
Default What exactly is a tune-up on a '07 Cruiser?
Is it just replacing the plugs and wires or are there other things that are done?
Mine has 55,000 and I replaced the plugs and wires a few months back. For the most part it runs great, but sometimes when driving for a while, it seams to be a little rough on acceleration at certain speeds. Wondering if there's something I should be looking at. Oh, I have a K/N drop in replacement air filter, too.
Old 15 Dec 2010, 07:28 am
WolfmanG's Avatar
Default Re: What exactly is a tune-up on a '07 Cruiser?
i think that's it for a tune up, but you may want to check the gaps on the plugs. Crewzin say's a 40 gap for non-turbo's and i think chromenut says .35 for turbo, but no platinum's, i think.
-Danny Wolfman G
Old 15 Dec 2010, 07:31 am
WolfmanG's Avatar
check it out
2001 PT Sparkplugs Gap NGK at .35!!
-Danny Wolfman G
Old 15 Dec 2010, 10:26 am
falconut's Avatar
I put Autolite Iridium plugs in and checked the gap, which I believe was 0.4. Oh, and mine is a non-turbo.
It runs really smooth most of the time, just occationally at different speeds it feels a little rough. Curious if there was something else that I might have missed looking at. I did change the pcv a while ago, too.
Old 19 Dec 2010, 12:43 am
WolfmanG's Avatar
I would prefer champions on a Chrysler. Autolites are more for ford. I used those for the Mazda pick up i had and my sis in laws Ranger.
-Danny Wolfman G
Old 19 Dec 2010, 08:26 am
What wires did you use for replacement? That's the ONLY electrical part you shouldn't get from the dealer unless you step up to the Blue MOPAR Performance wires.
MOPAR PERFORMANCE 7.5MM PT CRUISER-NEON PLUG WIRE SET - eBay (item 130451740343 end time Jan-03-11 16:43:02 PST)
Old 21 Dec 2010, 09:51 am
falconut's Avatar
I had purchaed Autolite wires from Advance Auto.
Old 27 Feb 2011, 09:07 am
I'm tuning up my 07 Cruiser (Non-Turbo) as well. I found these wires on ebay. Would they work?
MOPAR Performance NEON Spark Plug Wires set 96-01 2.0L - eBay (item 360343690832 end time Mar-13-11 08:50:18 PDT)
Old 27 Feb 2011, 02:26 pm
I'm not sure of the 2.0L engine compared to ours but they should work. I can't see there being a different in the space between the coil and plugs as as long as that's the same, they should be OK.
Falconut, that should be .040in not 0.4. but that could just be a typo on your part. If not, they need to be regapped. Plugs wires and fuel delivery should be the only things that need looking into. You might have a fowled injector that would be ok in normal driving but when full acceleration is needed, it's not able to give a full spray. They a large bottle of Chevron Techron in the gas tank when it's 3/4 to 1/2 full to try and clean any deposits in the fuel line and injectors.
Old 27 Feb 2011, 05:31 pm
mityqwik's Avatar
Thumbs up Re: What exactly is a tune-up on a '07 Cruiser?
replace your PCV while your doing the tune up
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
CRUISER - 30,000 mile tune up hoppyloop Tech & Performance Forum 3 22 May 2008 04:16 pm
New guy needs some tune up help MusiciansPT Tech & Performance Forum 5 02 Jul 2007 06:35 pm
The $6,600 tune up turbomangt The Detail Shop 2 09 Jan 2006 03:00 pm
