New timing belt, but now it roars
Old 17 Dec 2010, 10:10 am
Default New timing belt, but now it roars
Just finished getting the 2004 PT repaired for a grand total of $2400.
New fan module, thermostat and housing, new battery, new timing belt and water pump as well etc.
Picked it up yesterday and now when I step on the gas the damn engine "roars" loudly. It only does this when I accelerate. What would cause this to make my engine roar like this? Should I take it back?
Old 17 Dec 2010, 10:18 am
Default Re: New timing belt, but now it roars
Maybe they just unleashed the beast
Old 17 Dec 2010, 11:16 am
Dino's Avatar
What do you mean it roars? Like with no muffler? Is it a good roar or bad?
Old 17 Dec 2010, 11:48 am
It's hard to describe, but it's loud! Almost sounds like an exhaust roar but it's coming from the engine during acceleration.
Old 17 Dec 2010, 11:54 am
You probably should take it back to get them to put it back to the original condition. Judging by the work you listed, I cannot think of any reason for additional noise. When I replaced my timing belt, I think I disconnected the exhaust to lift the engine a little. If they did the same, perhaps they didn't get everything tightened properly.
Just my dos centavos.
Poncho Villa
2004 Base Model PT Cruiser, 5 Speed
Old 17 Dec 2010, 12:27 pm
Sounds like whoever worked on your car has left the intake unhooked. The same roar as you get when you add an aftermarket intake. It's the rush of air into the throttle body. Look around for an opening in the rubber intake flex hose either on the air filter end or the throttle body end.
P.S. Most of us like that "roar" when accelerating.
Old 17 Dec 2010, 12:55 pm
I've been goggling this and read that it might be a "balancer belt" that is misaligned. Does the PT have a "balancer belt"?
Old 17 Dec 2010, 01:07 pm
Did your Google have anything to do with a PT Cruiser? NO, no balancer belt. Timing belt, serpentine belt and alternator belt only. Please look at the intake, the rubber according type hose between the air filter and throttle body.
Old 17 Dec 2010, 01:29 pm
Ok, I'll check it out tonight! Thanks for taking the time to write these suggestions!
Timing belt kit? BladeRunner Tech & Performance Forum 16 22 Oct 2014 03:39 pm
timing belt cruiser4475 Tech & Performance Forum 0 13 Jul 2010 06:24 pm
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
Timing belt what a JOB!! 02PT Tech & Performance Forum 6 08 Dec 2009 06:31 pm
Timing Belt notadodge Tech & Performance Forum 11 25 Nov 2008 09:37 am
