Error Code P1131
Old 18 Dec 2010, 09:06 am
Default Error Code P1131
Hi, I've been reading this forum for a few years now & you've helped fix (my hubby really) a couple of problems & save me a few quid.......so thanks for that.
I've joined today because I searched the forum, but couldn't find anyone who'd had the same error code. I've discovered the code P1131 is HO2S Circuit Low Variance Bank 1 Sensor 2, but have no idea what that means!
I have a 2004 CRD.
Thanks very much.
Old 18 Dec 2010, 09:41 am
Default Re: Error Code P1131
Welcome to the forum.
You have the diesel engine which aren't made in the U.S of A. but maybe the code you getting is related to parts that we do have. Here in the land of the round door knobs (inside joke) we have 2 Oxygen sensors to help with emissions control. Not sure if they put them in the overseas models or not and really not sure if the Diesel engine has ANY emissions related parts. One sensor is right by the exhaust manifold, the other by the Catalytic Converter (again, not sure if you have that). They are known as Upstream and Downstream sensors because of where they are located.
If, you can doesn't have any of that emissions related equipment, there's no use listening to the rest of this.
One of the sensors (probably upstream) is seeing a bad input (probably lean condition) and has sent the trouble code to the computer to set the fault light. Over here, depending on the mileage, it's best to replace both sensors after a reasonable amount of mileage (+ or - 70-90,000).
Now after saying that, it might not be the sensor itself but something causing the lean condition which would make the sensor set the code. The diesel engine is a completely different animal compared to ours. Might have to diagnosed by a competent mechanic.
There is a really great United Kingdom PT Cruiser site and they are always willing to help out. They also have two other engines for the PT that we don't have here and one is the Diesel. Here's the site: http://ukcruisers.net/forum/
Old 19 Dec 2010, 01:23 pm
Thanks very much CREWZIN for taking the time to reply to my problem. I'll check out all the information you've given me and head over to the uk site too. Thanks again
Tags
error code, p1131
is it an error Code or something else saraPT04 Tech & Performance Forum 5 08 Oct 2010 02:46 pm
Error Code bus b8 or 68, not sure. richardbradley Tech & Performance Forum 2 18 May 2010 07:45 pm
Error Code 320 okla2001pt Tech & Performance Forum 1 17 May 2010 12:42 pm
Error Code bds02pt Tech & Performance Forum 2 29 Jan 2010 03:01 pm
CPS Error Code smokeydan1 Tech & Performance Forum 16 23 Sep 2008 09:58 pm
