Thansmission Leaking !!! Help.....
Old 19 Dec 2010, 02:17 pm
RedPT07's Avatar
Default Thansmission Leaking !!! Help.....
Hello Guys
I did a fluid change 3 months ago and I think the mechanic overfill the transmission because it took 4.75 qts, he was checking the level with engine running in neutral position. After that I've checking fluid with car cold 7 heat and the levels always show me at the top XXXX marks.
Yesterday I realize the transmission is leaking at the driver side leaking trhu the bumper running along the hose located there. I remove the Battery and the support to verify from top the leak doesn't come from a solenoid pack.
Help me guys.
Old 19 Dec 2010, 08:56 pm
Default Re: Thansmission Leaking !!! Help.....
Do you have a seperate cooler under the radiator?
Winter Transmission Fluid Leak
May possibly very similar to this thread. As I posted here, need to watch hoses and clamps for the hopefully only thing wrong!
Old 19 Dec 2010, 09:55 pm
RedPT07's Avatar
Thanks for the advice.
I will check the lines to see is coming from a loose clamp.
Old 22 Dec 2010, 10:14 pm
RedPT07's Avatar
Thanks murphy,
Were the hose clamps, they were not tight enough, thanks god.
And I already change ATF with filter today.
Leaking oil cap? CreepyPT Tech & Performance Forum 3 29 Oct 2009 12:16 am
Oil Leaking kairobsor Tech & Performance Forum 4 30 Aug 2009 01:10 am
water leaking six0fourgirl Tech & Performance Forum 18 02 Oct 2008 09:51 am
I may have a headgasket leaking 2004PTCruiser Tech & Performance Forum 2 20 Apr 2008 08:38 pm
oil leaking ptma767 General PT Cruiser Discussions 11 20 Feb 2008 07:42 pm
