P301 misfire code
Old 21 Dec 2010, 09:34 pm
Default P301 misfire code
Good evening to everyone.
My wife's 2001 PT Cruiser just went through a total rebuild by myself after overheating issue resulting in a #3 piston burn-through. I was very intimidated at the prospect of rebuilding this engine, but it turned out to be a dream (except for the removal). It ran great for the past 2 months and just recently started to have a miss mostly just as you start up a hill, but immediately stops once you accelerate and runs great thereafter. Now it is getting worse with a noticable miss on the acceleration and has a p301 code. Any ideas? I changed the plugs during the rebuild. The valves, pistons and rings, bearings, oil pump, timing belt, water pump, gaskets, and head magnafluxed.
Have been told maybe coil pack, plug wires, a bad plug, or #1 injector. I haven't had time to check any of these. Any other ideas? Thanks in advance and may each of you have a very Merry Christmas.
Phillip
Old 22 Dec 2010, 05:38 am
Default Re: P301 misfire code
Phillip,
You have mentioned the main culprits for the single cylinder misfire but start with the plug wires. You can move one wire from cylinder #1 and swap it for one of the other wires. Take off the negative battery cable for 5 minutes to clear the code and then see if the code comes back pointing to another cylinder.
Error Code P0304 Cylinder 4 Misfire Detected WV05Cruiser Tech & Performance Forum 16 23 Feb 2016 10:33 am
error code ques-... got a p0300- random misfire... batta Tech & Performance Forum 4 18 Apr 2010 03:26 pm
misfire no cel? jacarc1 General Turbo Discussions 4 17 Apr 2010 07:28 am
Misfire pntbalr Tech & Performance Forum 5 05 Dec 2009 09:45 pm
Code 0303 # 3 cylinder misfire Bob0815 Tech & Performance Forum 4 17 Sep 2009 08:21 pm
