Need new ignition cylinder, if I keep old key will car still start?
Old 23 Dec 2010, 06:47 am
Smifo's Avatar
Default Need new ignition cylinder, if I keep old key will car still start?
Hi all
2003 PT CRUISER CRD TOURING
I need to replace my ignition lock, as it keeps sticking, especially in very cold weather (anyone else had this?). My question is, if I keep the original key on my keyring, will the car still start ok? I've read a few posts about people struggling to reprogram key transponders, and don't want to be stuck without transport.
Thanks in advance for any help.
Cheers
Smifo
Old 27 Dec 2010, 03:47 pm
Default Re: Need new ignition cylinder, if I keep old key will car still start?
You'd probably just have to try unless someone on here has done it. According to Chrysler, the transponder isn't in range of the sentry system until the key is inserted into the lock cylinder. Perhaps if the key is kept close enough to the cylinder it will work.
-Chris
Old 28 Dec 2010, 06:01 am
Smifo's Avatar
Thumbs up Re: Need new ignition cylinder, if I keep old key will car still start?
Cheers for the input Chris.
I guess we're thinking along the same lines there. I think the question is, will the unpaired new key, in any way interfere with the signal from the old key? Or does the fact that its unpaired mean that it won't? And I see what you mean about how close it's gotta be, may be that I'd have to tape it to the new key.
Thanks again.
Smifo
Old 28 Dec 2010, 08:01 am
BGW BGW is offline
Smifo,
In Feb 2010 I replaced the ignition lock on my 2002 PT (non-turbo 5 speed). It was sticking in cold weather, like yours, and one evening (at work), the key refused to turn at all. After a tow to the garage, the ignition lock was deemed faulty and replaced. I am still using the original keys with no issue, nothing was reprogrammed at all.
Old 28 Dec 2010, 08:34 am
Smifo's Avatar
Ta for that BGW
I read somewhere that they put the immobiliser transponders in from 2003 onwards. Anyone know if this is accurate?
Smifo
Old 28 Dec 2010, 10:39 am
Originally Posted by Smifo View Post
Ta for that BGW
Smifo
That's inaccurate. Transponder keys were used all the way from 2001 PTs.
Just have a locksmith re-key your new lock cylinder to your original key, or see if the dealer can order a cylinder already keyed to your original. Then you won't have to worry about an unpaired key in the first place.
-Chris
Old 28 Dec 2010, 11:05 am
Smifo's Avatar
Ta heifetz17
Have just sent an enquiry to an auto locksmith.
But the reason for my original question was obviously that I was trying to avoid using dealers or locksmiths. Dealer quoted me 150 ($200+), barrel off ebay is about $40.
Cheers
Smifo
Old 28 Dec 2010, 11:27 am
BladeRunner's Avatar
You could try spraying some graphite lube in the ignition lock..might free things up. I have used it on a stubborn locking gas cap..it's wet going on but quickly drys...smooth as silk now; Be careful though..it's very fine and BLACK and gets everywhere if you don't pay attention.
Tags
chip, ignition, immobiliser, key, transponder
Cylinder 3 misfire michalo187 Tech & Performance Forum 12 28 Jan 2017 09:30 pm
Replacing Ignition Lock Cylinder--Done Matt42 Tech & Performance Forum 2 20 May 2010 10:10 pm
Does not start (no ignition / electrics OK) - HELP!! aljimtom Tech & Performance Forum 6 30 Dec 2009 11:13 am
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
Cylinder Misfire TaylorMade Tech & Performance Forum 6 16 Jun 2005 05:01 pm
