Coolant leak
Old 23 Dec 2010, 02:16 pm
Default Coolant leak
I have a bad coolant leak on my 2003. Coolant is pouring out on the passenger side of the engine. I know that sounds like the water pump, but I'm hoping it's not, since I had a new one installed when I did my timing belt (about 10,000 miles ago). Before i get in there to look, does anyone know of anything else it may be? Obviously I'll look at the lower radiator hose, but maybe there's something else? Like I said, it's pouring out, not slowly leaking.
Old 23 Dec 2010, 02:31 pm
mityqwik's Avatar
Question Re: Coolant leak
hope its just your bottom hose that would be an easy fix,the other the WATER PUMP harder fix i hope its not that the pumps should last a lot longer and if you had a stealership do the work it might have a warrenty of some kind.
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
Old 23 Dec 2010, 04:08 pm
Default Re: Coolant leak
We could take guesses all day but until you get in there and see what's leaking, you'll never know.
Old 24 Dec 2010, 08:36 pm
mdfrodolives's Avatar
Check directly under your thermostat housing cover (it's the black pipe that has your radiator cap on top of it). Mine was leaking slowly--but maybe your thermostat gasket is being a bit more passionate.
Also, check your heater-core hoses; then check your lower radiator hose on both ends.
Good luck,
Tim
Coolant Leak TimWeaver Tech & Performance Forum 6 13 Jul 2012 08:55 pm
PLz help= Coolant leak PtC06 Tech & Performance Forum 2 04 Dec 2010 02:01 am
Coolant Leak dfales General PT Cruiser Discussions 7 18 Dec 2009 06:30 pm
Coolant Leak rcalzadilla Tech & Performance Forum 29 25 Oct 2009 01:29 pm
coolant leak RaceWilson Tech & Performance Forum 7 14 Sep 2008 09:49 am
