Whining noise from engine
Old 23 Dec 2010, 03:15 pm
Default Whining noise from engine
Hello everyone,
I have a 2003 PT Cruiser, I have been hearing the sound of a whining noise like a bearing is going out in the engine. My car has 117,000.00 miles on it, and everything seem to be working good except for this noise. Can you tell me what the problem could be, and could I fix this myself? I have had the timing belt and water pump done at 90,000
Thank you,
Leroy
Merry Christmas and Happy Holidays.
forrests6@yahoo.com
Old 23 Dec 2010, 04:03 pm
Default Re: Whining noise from engine
Leroy,
Sorry to hear about your noise but there's just not enough information to go on to pin point what the problem is. First of all, is it a Turbo or Turbo Lite or neither? Does the noise change with speed of the engine? Try to have someone experience stand by the open engine compartment and listen for the noise and see if they can isolate it.
Old 23 Dec 2010, 04:19 pm
I do not have a turbo engine, the noise is coming from around were the power steering pump is. Could there be a bearing going out in a pulley for the belts?
Thank you for any input on this problem.
Leroy
Old 26 Dec 2010, 11:48 pm
i had a whining noise in mine ,turned out to be a wheel bearing
Old 27 Dec 2010, 12:02 pm
Check your tensioner pully. Apparently the bearings in mine froze. At least it's an easy thing to get at.
Old 27 Dec 2010, 01:52 pm
Thank you,
I did not know that my car had a tensioner pully for the belt. I had this fixed on my RV when it was making the same noise. It looks like that will be the first thing that I check to see if that is the problem. I would think that you are right about this, again thank you for the information.
Leroy
Weird rumbling noise in dashboard when I turn over the engine/ turn off the engine... thinkinboutit Tech & Performance Forum 5 22 Jan 2014 08:23 pm
Whining / grinding noise. PtOnAir Tech & Performance Forum 13 09 Dec 2012 04:44 pm
Whining noise when turning PTBoozer General PT Cruiser Discussions 4 01 Mar 2010 12:13 pm
whining noise coming from car? feefeethaflee Tech & Performance Forum 14 14 Feb 2010 10:50 pm
whining noise when acceleration??? ruzz1 Tech & Performance Forum 9 09 Nov 2007 07:46 pm
