Changing PCM and TCM together
Old 26 Dec 2010, 11:22 pm
Default Changing PCM and TCM together
I have a 2002 PT Cruiser with a check engine code of P0605, which is the TCM. It's an automatic that won't shift out of first gear despite the speed. If I buy a used PCM and TCM from the same vehicle (another 2002 model) would I have to flash them? I'm assuming the TCM is flashed to the PCM, but if they both came from the same vehicle, wouldn't they already be flashed to each other?
Changing out motors wareagleguy Tech & Performance Forum 2 20 Jan 2010 08:37 pm
Changing the battery PTJake General PT Cruiser Discussions 14 20 Dec 2007 11:35 pm
changing oil tm05cruiser Tech & Performance Forum 1 31 Oct 2007 12:10 pm
Changing Map Light? Speed Lab General PT Cruiser Discussions 1 27 Nov 2002 09:03 am
Changing the PCV Valve emery Tech & Performance Forum 2 07 Dec 2001 05:05 am
